05-31-2016, 12:33 AM | #1 |
I wanna be Dave Join Date: Apr 2007 Location: We-Go, Chi-Town, Ill
| Prepping Bare Metal RC4wd Wheels for Paint
I bought set of the bare metal 1.55" Landy's for my Tamiya MF-01x and still have yet to paint them. Is there a recommended surface prep prior to laying down any primer then paint on them? A month or so ago I picked up some self etching primer from the local Napa and was probably going to use one of Model Master's 2 stage lacquer paints as a color and clear coat, but wasn't sure what would work best to clean any of the manufacturing and packaging chemicals off the metal and and other metal prep work that might need to be done to them prior to laying down the primer. Any suggestions?! Thanks! |
06-01-2016, 11:03 AM | #2 |
I wanna be Dave Join Date: Mar 2013 Location: Minden
| Re: Prepping Bare Metal RC4wd Wheels for Paint
I have a posting in paint and no body has commented and close too a hundred have looked and one has if I did it wrong I painted a set of aluminium beadlocks with etching primer and flat camouflage spray paint and then used Testers Dullcote which is flat lacquer I have not mounted them waiting on tires and foams I bought scuffing wheels for my Dremel there made out Scotch Bright pads And scuffed up the both wheel halves and the SLW hubs Then scrubbed them using dish soap and water and some ISO too make sure they were clean The black socket caps hardware looks good Did I say look good I meant to say Damn Sexy !! Last edited by kgb424; 12-11-2018 at 01:35 AM. |
06-01-2016, 12:14 PM | #3 |
RCC Addict Join Date: Nov 2008 Location: Frederick
A good sanding, cleaning and primer is enough for steel. If it was Alum I'd recommend using an adhesion promoter after cleaning. That's how I did these Proto Prangs |
06-01-2016, 01:10 PM | #4 |
Thanks guys, I appreciate it! Got the next couple days off work, maybe I'll hit the local NAPA for a surface prep cleaner to use on them.
06-01-2016, 01:53 PM | #5 |
Rock Crawler Join Date: May 2009 Location: Welderville just south of benchviseland
Brake parts cleaner to remove any residue, scotch brite pad, hose them down with brake parts cleaner again, blow 'em off with the air hose, prime and paint. That's pretty much how I treat all my bare-metal bits and pieces and I have yet to experience fish-eye.
06-03-2016, 10:45 AM | #6 |
RCC Addict Join Date: Dec 2009 Location: Laceys Spring, Alabama
X2 on this method. I've done four sets like this and they've all turned out great. |
Prepping Bare Metal RC4wd Wheels for Paint - Similar Threads | ||||
prepping a Wraith body for paint | YYCADM | Paint and Body | 20 | 08-01-2015 08:39 AM |
Bare Metal! | George014 | Axial SCX-10 | 0 | 01-01-2013 08:03 AM |
NEW RC4WD Dick Cepek Gun Metal 7 1.9" Internal Beadlock Wheels | RPP Hobby | RPP Hobby | 1 | 10-08-2012 09:56 PM |
