06-23-2016, 02:34 PM | #1 |
Rock Crawler Join Date: Jan 2005 Location: The Hills
| State License plates?
I'd really like to have an official WV state License plate for my body. Is there anyone out there that prints them up? Thanks!
06-23-2016, 02:37 PM | #2 |
Rock Crawler Join Date: Aug 2015 Location: Big Island
| Re: State License plates?
You can print your own from this site ACME License Maker |
06-23-2016, 02:52 PM | #3 |
Quarry Creeper Join Date: Jun 2013 Location: Canada
| Re: State License plates? |
06-24-2016, 05:24 AM | #4 | |
Pebble Pounder Join Date: Jul 2013 Location: England
| Re: State License plates? Quote:
If you have access to a printer, you can make you own really easily (plus custom stickers for your body and other scale accessories such as smartphones & iPads), hope this YT video of mine helps... https://www.youtube.com/watch?v=V7z1GG7jcDU | |
06-24-2016, 06:24 AM | #5 |
There's some guy on Facebook that does awesome aluminum license plates.
06-24-2016, 08:20 AM | #6 | |
I joined the Band! Join Date: May 2015 Location: Dallas
Two main guys - krawler konceptz does nice work...they use a scale reflective material and also include micro hardware. Rcdmv doesn't use reflective material and doesn't include hardware but is cheaper. I've ordered from both and would give the slight nod to KK. The actual print itself isn't as 3D as rcdmv but the reflective material and hardware give it the edge. avgatbest | |
06-25-2016, 07:01 PM | #7 |
I wanna be Dave Join Date: Dec 2006 Location: Where the sheep run scared.
I second Krawler Konceptz out of Canada. I have several of their plates and they are all killer |
05-09-2018, 02:27 PM | #8 |
Yes old thread is old Here's my DIY method for license plates. First I'll make up a handful of plates using the Acme license maker's site, laminate them, cut them out then I'll cut a matching piece of lexan out and I paint just the edge of the lexan so it looks like sheet metal. To bond the 2 I've really liked using 3M's super 77 (a multipurpose adhesive) its like a contact adhesive with a lot move forgiveness, it wont just bond where you set it instantly, you have a bit of time to play with it. I also found with heat you can get the bond to loosen up and when cool it will stay put. I live in a cool area and its possible this adhesive may not do as good in hotter climates. I use painters tape to hold the plate down (sticking it face down) while I spay the super 77 on the back side, it also prevents the adhesive getting on the front side Let it sit for 5 minutes until tacky, then carefully align them and stick them together. I like to either use tiny scale hardware to mount the plate to the truck or E6000 if its in a spot that its less likely to get knocked loose. but I have lost a handful of plates when using hot glue, so I'd avoid using it alone. |
05-09-2018, 02:35 PM | #9 |
Newbie Join Date: Jul 2012 Location: Honolulu
My support for Krawler Konceptz too. My apologies upfront but...stay home mom that takes care of special needs son (also has a daughter) and supports special needs organizations/events! Awesome in my book. Easy to work with and does great custom work too! I've been doing the Acme plates until I found KK. Now I'm hooked.
05-09-2018, 04:15 PM | #10 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
I create mine on the Acme sight, laminate with clear packing tape, cut them out and lay them, face-up, onto the sticky side of aluminum tape. I do this, with the aluminum tape 3 or 4 times, then I cut off the excess around the edges. Makes it resemble aluminum plates and it's reasonably stiff.
05-16-2018, 10:08 AM | #11 |
Cryptic RC is a new company on Facebook doing plates. I didn't realize KK included scale hardware. That's sweet! |
05-16-2018, 04:10 PM | #12 | |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
Does plates and other stuff as well. | |
05-17-2018, 07:20 AM | #13 | |
05-17-2018, 08:49 AM | #14 |
I wanna be Dave Join Date: Sep 2009 Location: Eastcoast CANADA
Thanks everyone for the kind words |
State License plates? - Similar Threads | ||||
License Plates | Krawler Konceptz | Scale Nationals | 7 | 09-14-2012 05:51 PM |
License Plates for Scalers | turtleshuffle | Losi Micro-Rock Crawler | 2 | 01-25-2010 09:06 PM |
license plates... | Big Mike | Scale Accessories | 13 | 12-07-2006 08:26 AM |
