06-26-2016, 05:30 AM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: Wind Gap
| Body mounting?
I am curious as to how you guys mount your lexan bodies from the side instead of drilling holes in the top, are there mounts you can buy or do you fabricate them yourself? Any help would be greatly appreciated, Thank you.
06-26-2016, 06:24 AM | #2 |
Rock Crawler Join Date: Sep 2009 Location: Bloomsburg, pa
| Re: Body mounting?
magnets, you can buy magnetic mounts but making your own isnt super complicated.
06-26-2016, 07:09 PM | #3 | |
Rock Crawler Join Date: Feb 2009 Location: Wrightstown
| Re: Body mounting? Quote:
I second this, I make as many trucks magnetic as I can. I just cut the nipple off of the body mounts, file them flat and Shoo goo/E6000 them on. Glue magnets to the body, also with Shoo Goo/E6000, holds up really well. | |
06-26-2016, 08:18 PM | #4 |
Quarry Creeper Join Date: Feb 2015 Location: Corpus Christi
| Re: Body mounting?
Ok but, does the body stay in place after tumbling down a 10 ft climb that went wrong? Or when the truck gets wedged and the body gets used as a slider in a crevice? I like the idea, just not sure if they'll hold up to abuse. Sent from my XT1585 using Tapatalk |
06-26-2016, 08:39 PM | #5 |
| Re: Body mounting?
In a big fall, no the body usually pops off. The magnets that I use, I can pick up my truck with the body. It's about 7 lbs. You actually have to twist the body to get it to pop off. Works great for me, but if you drive your truck like a comp truck and force it thru every thing I'd stick with body pins. |
06-27-2016, 11:53 AM | #6 |
Quarry Creeper Join Date: Jun 2015 Location: Petaluma, Ca
| Re: Body mounting?
I use velcro to mount my bodies. It works very good.
Body mounting? - Similar Threads | ||||
Mounting a Hilux body without body clips? | OrangeTJ | General Scale Talk | 8 | 11-06-2013 06:51 AM |
Body mounting ?'s | Corey123 | Paint and Body | 6 | 03-12-2012 11:58 PM |
Body mounting???? | flyingrc | Paint and Body | 6 | 02-26-2012 04:36 PM |
mounting body help | californiadrft | Axial SCX-10 | 6 | 08-14-2009 10:11 PM |
mounting body | rubiguy | Axial AX-10 Scorpion | 5 | 02-10-2009 04:01 PM |
