10-06-2016, 07:09 AM | #1 |
Pebble Pounder Join Date: Dec 2011 Location: milford
| painting lexan on the outside. paint suggestions?
ive painted alot of lexan bodies but they have always been on the inside. Heres my question. I want to paint my body a specific tan / sand color but its not available anywhere in a lexan paint and i only really use spray cans (tried air brush...epic fail) is there a specific technique to get thje paint to stay on the body without it flaking? its a new body and i dont want to mess it up but i dont have a spare to try things on. any ideas? |
10-06-2016, 07:31 AM | #2 |
Quarry Creeper Join Date: Feb 2015 Location: Corpus Christi
| Re: painting lexan on the outside. paint suggestions?
Ive been using rustoleum paints lately. I've had good success, by sanding and scuffing up the body first. Then make the first coat very light. The last one I painted is holding up very well. There are a couple of spots where I missed the Sanding and the paint is starting to come up, but thats my own fault. I paint on the inside though, not sure how it'll work painting the outside. When it comes to using non lexan paints, prep, and application is key. Hell Ive have lexan paint flake off before. Here's a pic of my last body. Used Rustoleum camo tan. Can says it works on plastics. So far so good. Sent from my XT1585 using Tapatalk |
10-06-2016, 07:34 AM | #3 |
yea thats kinda the color im goin for..thats on the inside correct? i would hate to do all the masking and paint only to have it flake after hitting a blade of grass..
10-06-2016, 09:46 AM | #4 |
It's on the inside. Backed with black. Like I said it's very important to sand the body before painting and make the first coat very light. This body has taken a lot of nasty hits and the paint is holding up well. This is the paint I used. If you look at the first pic you can see a spot at the rear of the roof that looks like it's coming off. It hasn't yet, it's the only spot that is showing signs of a mistake. Sent from my XT1585 using Tapatalk Last edited by Waitwhatsthat?; 10-06-2016 at 09:49 AM. |
10-06-2016, 10:42 AM | #5 |
For outside lexan body painting I just use Tamiya or Duratrax spray paint, no scuffing needed, works great. Post #231 and onward you can see my Honcho painted with Duratrax spray paint. The body was very rough before with lots of scrapes, scratches, cracks. I ShoeGoo the cracks with drywall mesh tape, dry overnight and painted. Natedog's Honcho kit build Edit: The paint has held up very well and does not scratch easily at all. Last edited by Natedog; 10-06-2016 at 10:45 AM. |
10-06-2016, 10:53 AM | #6 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
I've used the same line of Rustoleum metioned above and it holds up great. I hit the outside of the body with a scotch brite pad first to very lightly rough up the lexan.
10-06-2016, 10:55 AM | #7 |
Rock Crawler Join Date: Dec 2013 Location: Norway
The thing is that if you want to paint your lexan with anything else than lexan paint, go right ahead. But paint a primer layer with lexan paint first so the other paint sticks to the lexan. If it is on the outside you want to paint. Prime with a lexan paint relative to the paint that goes over. If it is on the inside you want to paint, use a layer of tamiya ps55 first so it sticks. Personally I lean towards outside paint on scalers, looks more realistic. |
10-06-2016, 11:33 AM | #8 |
yea, thats why i wanna do the outside..so u looks alittle more real than shiny plastic...my kit should be here in the next few days, gonna see which way i do it..im gonna cringe and go for the outside paint..lol..it goes against everything ive ever done with lexan...lol.
10-06-2016, 06:52 PM | #9 | |
RCC Addict Join Date: Jun 2004 Location: ORegon
| Re: painting lexan on the outside. paint suggestions? Quote:
10-06-2016, 07:35 PM | #10 | |
10-07-2016, 05:02 AM | #11 |
ok..thanks guys. i appreciate the ideas. anyone else have pics of the outside paintjob on lexan?
10-07-2016, 08:26 AM | #12 |
I found this link - it may be helpful in letting you actually see the basic process of painting Lexan inside and then outside, including window frames: https://youtu.be/Swnet3ELNZs |
10-07-2016, 02:11 PM | #13 |
I thought I should share some photos of the paint job i was talking about. Again, it was Tamiya PS-5 Black inside and out, and then Testors Flat Black Enamel Spray on the outside. Note: glossy sections and windows were simply trimmed from the protective film on the outside (and left on while applying the paint to the outside) to reveal the glossy lexan beneath at the end. |
10-07-2016, 07:05 PM | #14 | |
Painted on the outside using Krylon and Testor's flat colors after using a polycarbonate paint first. Last edited by Mike Flea; 10-07-2016 at 07:10 PM. | |
10-08-2016, 07:35 PM | #15 |
Rock Crawler Join Date: Mar 2012 Location: bel air
| Re: painting lexan on the outside. paint suggestions? I paint all my bodies on the outside.. use a base layer of polycarbonate silver paint as primer as discussed before, but I use silver specific to mimic the "metal" under as the color layer paint gets scraped off. For an extra level of detail, paint copper on the inside so as the body gets beat up and the plastic gets gouged you will see "rust" thru the paint Sent from my SAMSUNG-SM-G870A using Tapatalk |
10-08-2016, 07:47 PM | #16 |
Here's a shot of one that's seen some abuse. Note the rust around the headlights and the fender corners Sent from my SAMSUNG-SM-G870A using Tapatalk |
10-08-2016, 07:57 PM | #17 |
What color are you looking for, Tamiya has a nice sand color.. Sent from my SAMSUNG-SM-G870A using Tapatalk |
10-09-2016, 07:44 AM | #18 | |
Newbie Join Date: Jan 2014 Location: Springbrook
Sent from my iPhone using Tapatalk | |
10-27-2016, 04:52 AM | #19 |
| Re: painting lexan on the outside. paint suggestions? I caved in and painted from the inside..lol...i just didnt wanna make a mistake ...i like the outcome. Sent from my SM-G930V using Tapatalk |
10-27-2016, 06:04 AM | #20 |
Looks good. I recently repainted mine on the outside. Happy with how it turned out. It looks better with more scratches on it. Sent from my XT1585 using Tapatalk |
painting lexan on the outside. paint suggestions? - Similar Threads | ||||
painting with non lexan paint | scalemadness | Paint and Body | 7 | 04-25-2014 05:23 PM |
Lexan Shell Paint Disaster, Paint Removal? | Big Tex | Paint and Body | 15 | 02-08-2012 12:58 AM |
Painting lexan? | run2jeepn | Paint and Body | 29 | 06-26-2011 07:25 PM |
Painting lexan on the outside.. | tjb | Paint and Body | 5 | 03-06-2007 12:09 PM |
