10-24-2016, 06:59 PM | #1 |
Pebble Pounder Join Date: Mar 2015 Location: Ontario
| Removing paint from hardbody
Whats the best way to take the old paint off my TF2 body? I want to strip it down and repaint it this winter.
10-25-2016, 08:45 AM | #3 |
| Re: Removing paint from hardbody
Acetone with 25% water......you need the water to prevent melting. Quick and easy Hang up and Drive |
10-25-2016, 12:39 PM | #4 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
I've used Castrol Super Clean in the past for static models with no ill effects to the plastic. I've read others have used brake fluid, but it's messy. I might have to try that acetone method...I like the "quick" methods. I have no patience... |
10-25-2016, 01:16 PM | #5 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
A light sanding and then more paint... Why remove anything?
10-25-2016, 01:47 PM | #6 |
Acetone and water is an old styrene builders trick. We would drop spare sprue into to make sure no damage was done. Hang up and Drive |
10-25-2016, 02:46 PM | #7 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
You could try easy-off oven cleaner or brake fluid....
10-25-2016, 03:55 PM | #8 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
I tried easy off on my tf2 it did start to soften the plastic i just sanded mine down and repainted
10-25-2016, 08:15 PM | #9 |
Thanks for the tips guys!! Not sure which method I'll use yet, I'm going to wait until the snow flies anyways.
Removing paint from hardbody - Similar Threads | ||||
Removing Glue From Hardbody Shells | jhedsy | Tools, and Procedures | 10 | 02-10-2013 08:14 PM |
Removing old paint.. | PCHILNSF | Paint and Body | 2 | 08-25-2011 01:34 PM |
Removing stickers from hardbody | dezslash | General Scale Talk | 4 | 12-21-2009 10:53 PM |
removing paint | must85 | Paint and Body | 9 | 10-23-2009 09:22 AM |
Removing paint?? | msd44 | Paint and Body | 20 | 03-19-2008 09:51 AM |
