Masking the windshield Hi, I'm about to start the paint-job for my new Gelande II D90. What would be the best leak-proof method to use with the windshield and the windows? Should I use tape or liquid masks? Thanks. |
Re: Masking the windshield Put a double layer of blue masking tape all over the piece, then cut out the mask from to-be-painted areas including the gasket with a sharp knife. Be careful. Don't forget to mask the inside of the windshield too and after your paint has cured, paint the gasket black by a brush or a good marker. Normal masking tape may let the vapours of solvent through and result in frozen window effect. |
Re: Masking the windshield I'm a little confused as to what needs masking off ? I thought the windshield's clear plastic insert is removable ? besides... even if ya did mask off the insert... and screwed that up during the process... it's replaceable. RC4WD Land Rover Defender D90 Plastic Clear Window Set Z-B0053 Gelande 2 Body Set - rc Bitz Possibly I'm misunderstanding what the OP wants to do ? |
Re: Masking the windshield Quote:
What do you mean by 'blue masking tape'. Is it a particular product? a brand? |
In the link you provided, the windshield is the lower part. Of this part, the area that needs masking is just the big rectangle with the rounded corners. All the resit is supposed to be metal and therefore should not be masked. |
duct tape !? :razz: Lol/no |
Re: Masking the windshield I have found the best practice for eliminating paint bleed, is to do the first 2 coats very very light. Just a single pass or 2 for the firts 2 coats. This allows the paint to seal that edge, without excessive evaporation, which can push up the tape. Of course, you want to make sure all your tape lines are firmly pressed down before the first coat. |
Re: Masking the windshield There's another painter tape that is green, sometimes called Frog Tape, that seals better on the edges than the blue. check out frogtape.com |
