11-12-2016, 07:27 AM | #1 |
Pebble Pounder Join Date: Oct 2009 Location: Australia
| Help bending styrene rod.
I'm trying to bend 1/8th styrene rod around this edge of my jeep body and it keeps snapping when I try to glue it using plumbers pvc priming fluid(mek), would I be better off using quick set CA or is there a way to bend the rod with heat maybe?
11-12-2016, 08:20 AM | #2 |
Quarry Creeper Join Date: Jun 2015 Location: Petaluma, Ca
| Re: Help bending styrene rod.
Yes use a heat gun but don't heat it to much or it will melt.
11-12-2016, 04:03 PM | #3 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
I'm pretty surprised you've built that much with styrene yet haven't realized that you can heat it to bend it yet. Yes, take a hairdryer/heat gun on a moderate setting and apply to section you want to bend. Like rere said don't get too hot or else it'll deform too much.
11-12-2016, 04:40 PM | #4 |
Pebble Pounder Join Date: Oct 2009 Location: Tacoma
With the hollow styrene rods I would take a piece of wire rod that fit snugly inside it an slowly bend to shape. It worked great for building roll cages it 1/24 1/25 scale model cars.
11-12-2016, 05:55 PM | #5 |
Rock Crawler Join Date: Aug 2007 Location: Philadelphia
^^^^ This guy knows whats up.
11-12-2016, 07:25 PM | #6 |
Light a candle, hold your 1/8 rod an inch or so above the flame ( high enough it don't catch fire), and when it starts becoming limp, make your bend, or bend it around where you want it to go, hold it until it cools, and you're done.
11-12-2016, 07:38 PM | #7 | |
| Re: Help bending styrene rod. Quote:
11-15-2016, 07:18 AM | #8 |
Rock Crawler Join Date: Dec 2007 Location: MERICA!
Looking sweet.
11-15-2016, 12:35 PM | #9 | |||
X2 | |||
11-15-2016, 01:10 PM | #10 |
| Re: Help bending styrene rod. |
11-16-2016, 03:52 AM | #11 |
Thanks guys, gonna try the heat gun method.
11-16-2016, 09:34 AM | #12 |
| Re: Help bending styrene rod. OK, thanks. Seemed a little self defeating to leave the metal rod inside the plastic tubing since it adds weight that is not necessarily down low. I'd just do the heat gun or a candle without the metal inside the styrene tube.
11-24-2016, 12:47 PM | #13 |
Quarry Creeper Join Date: Aug 2016 Location: British Columbia
11-24-2016, 01:57 PM | #14 |
I've built many styrene roll cages and found heat is more trouble than help . I use warm water and let my rods sit.with 1/8 dia solid I just bend on a flat surface. Hang up and Drive |
11-25-2016, 03:53 PM | #15 |
Fan of wheelspeed Join Date: Jun 2011 Location: Southern IN
I've heard of guys using water in them, freezing it and then using heat to bend. Ive never tried that one, but I do know that you can cap both ends of the tube before heating and bending. It'll help keep air in the tube and help in keeping it from collapsing completely when you bend it.
12-06-2016, 06:12 AM | #16 | |
Rock Crawler Join Date: Mar 2012 Location: bel air
I would recommend using guitar strings, they come in many thicknesses and can be pulled free easily. This is how I "mandrel " bend my brake line for chassis/rollcage projects. I don't see it being any different using plastic tubes/rods Sent from my iPad using Tapatalk | |
12-06-2016, 08:59 AM | #17 |
RCC Addict Join Date: Apr 2015 Location: New Brunswick,Canada
I'm no sytrene expert but maybe 3 or 4 relief cut where you tend to bend and the apply some glazing spot putty.. |
12-06-2016, 04:35 PM | #18 | ||
Interesting, thanks. | ||
12-07-2016, 11:58 AM | #19 |
Pebble Pounder Join Date: Oct 2015 Location: Atkinson, ME
The guitar string/piano wire trick is an oldie but is, IMO, the best way to bend plastic tube. Slide it in, heat VERY gently, bend, and pull it right out once its cool. Another great tool is outside spring benders. I have a set of these and have used them in the same way. Gentle heat and bend. https://www.amazon.com/Small-Parts-5...=bender+spring |
Help bending styrene rod. - Similar Threads | ||||
where to buy 3/8 or 5mm solid styrene rod? | LoneRanger | Tools, and Procedures | 5 | 02-25-2015 04:29 AM |
Bending soild rod | eric113 | Tools, and Procedures | 46 | 01-13-2012 07:05 PM |
Bending delrin rod | draper_88 | Tools, and Procedures | 2 | 11-12-2010 06:34 PM |
Molding/Bending/Melting Styrene | millrtme | Paint and Body | 0 | 04-16-2010 08:43 PM |
Bending solid 3/16 rod? | TLTCrawlin | Newbie General | 7 | 01-02-2007 03:45 PM |
