11-22-2016, 06:26 AM | #1 |
Quarry Creeper Join Date: Mar 2016 Location: Moses Lake
| Tamiya F350 hard body
so this is my first hard body that i bought for my RC truck Hauler, was wondering what everyone used to fill in holes? like on the side where it is normally attached to the truck with screws i plan on using velcro under it like i did with my proline lexan body, but want to fill in the holes before i paint. Also do you still need to use the polycarbonate paint? or any paint for plastic will work? Also any tips on painting would be greatly apprecated thanks. |
11-22-2016, 09:17 AM | #2 |
Newbie Join Date: Oct 2016 Location: Comox
| Re: Tamiya F350 hard body
Hey buddy Velcro won't hold the hardbody and paint wise tamiya Ts primere white or grey and ts paint Sent from my iPhone using Tapatalk |
11-22-2016, 11:05 AM | #3 |
thanks man, velcro should hold for what i use the truck for....i don't crawl with it just pulls a trailer with either my mud truck or wraith on it, maybe up and down some trails. i have doing some looking and have read that Krylon or rustolium spray paints work really well as well?
11-22-2016, 01:06 PM | #4 |
Quarry Creeper Join Date: Jun 2015 Location: Petaluma, Ca
I used body putty to fill all of my holes in. I use velcro to hold my body on and it works just. I use mine the same as you plan. I painted mine with Paint from the hardware stores that works on plastic.
11-22-2016, 01:10 PM | #5 |
| Re: Tamiya F350 hard body has the body putty cracked or shrank? ive read that body putty will do that. ok maybe i will try some krylon read it was great with plastic.
11-22-2016, 01:21 PM | #6 |
Haven't had any problems yet. Just put it on in stages.
11-22-2016, 01:39 PM | #7 |
ah, so little at a time let it dry then add more?
11-22-2016, 04:37 PM | #8 |
Quarry Creeper Join Date: Nov 2013 Location: alberta
Holes can be filled with styrene rod then skim coated with filler to finish it off
11-22-2016, 06:17 PM | #9 |
Velcro does work well, and if you do decide to run it a bit harder you can always go to rare earth magnets to hold the body on.
11-22-2016, 06:19 PM | #10 |
Quarry Creeper Join Date: Aug 2013 Location: Bullard TX
I filled with styrene then body putty to skim it smooth. Just don't go too thick at a time and do several layers.
