12-21-2016, 07:58 AM | #1 |
Rock Stacker Join Date: Oct 2008 Location: In the Middle of a Corn Field
| Beast II Body Questions/Recommendations
I have finally started working on my Beast II body, I have made great progress. However, I am wanting to get input before I go much further. I was wondering what the best paint/primer to use is? Do I need to sand the body before painting? If so, what grit sand paper should I use? What is the best filler/putty to use on styrene bodies? Thanks! |
12-21-2016, 11:27 AM | #2 |
Rock Crawler Join Date: Nov 2014 Location: Dells
| Re: Beast II Body Questions/Recommendations
No sanding unless you want to. Just about any paint will work. I use tamiya acrylics. Use styreen as filler. Then use the glue to melt it into the shape you want. |
12-22-2016, 08:13 PM | #3 |
I wanna be Dave Join Date: Apr 2014 Location: North Carolina
There are lots of good paint choices. I happen to like Tamiya and Model Master, but I've also gotten good results from Valspar cans at Lowes. I prefer the colored paint to have a flat finish (easier to work with) and then use clear coats to build up to the desired level of gloss.
Beast II Body Questions/Recommendations - Similar Threads | ||||
rc4wd beast body build? | whitrzac | Paint and Body | 1 | 02-02-2016 03:31 PM |
Beast II questions | mcsgt98 | Multi Axle Rigs | 3 | 11-01-2015 01:46 PM |
Rock Beast 2.2 on Scx10 RTR Rubi- Body ? | MurderedJK | Newbie General | 0 | 04-24-2014 12:20 PM |
Body recommendations? | Freakshow185 | 1.9 Scale Rigs | 6 | 11-20-2013 11:20 PM |
