01-31-2017, 11:57 AM | #1 |
Quarry Creeper Join Date: Oct 2009 Location: Indianapolis, IN
| DIY Flare Idea
This may have been done before but I thought I'd post it up in the event that is has not. I'm building a replica of my 1:1 Ram and haven't been able to find flares which would match the look of my truck. I thought about trying to shape and bend delrin rod or gluing styrene sheets toger and sanding but neither sounded like something I had a big degree of confidence in. I went hunting in my garage to see what I could find and came up with a handful of adhesive backed foam pads desiged for orbital type hand sanders, like these: https://www.amazon.com/uxcell-Square...am+sanding+pad They're almost like a low grade neoprene, kind of hard to describe. I grabbed one, traced the outline of the fender opening and cut out a test piece. I stuck it to the body and went to work on it with a dremel sanding drum. It sands very easily so when I try to make the actual flares I'll have to take it slow on the shaping but I think it'll yield a decent finished product. I don't intend a lot of hard core crawling with this rig but as long as the adhesive holds I think they'll take some abuse considering they're foam. Time will tell if these are a viable option but I figured I'd share the idea for others who may be trying to do the same thing. Last edited by Phylodog; 01-31-2017 at 12:07 PM. |
01-31-2017, 12:11 PM | #2 |
Rock Stacker Join Date: Jan 2015 Location: Midwest City
| Re: DIY Flare Idea
Good idea. I used automotive vacuum hose split down the middle on my powerwagon. Held on with E6000. worked like a charm.
01-31-2017, 06:52 PM | #3 |
| Re: DIY Flare Idea
You can also use windshield wiper rubber. The lexan fits nicely into the groove, and glue on with E6000 or Shoo Goo.
DIY Flare Idea - Similar Threads | ||||
Fender flare idea | cyberhog05 | 2.2 Scale Rigs | 7 | 03-19-2016 03:12 PM |
DIY Hexes idea | goslo | General Crawlers | 10 | 07-16-2008 04:11 PM |
