03-15-2017, 02:02 PM | #1 |
Newbie Join Date: Mar 2017 Location: cadillac
| Long wheel base
I'm pretty new to RC so please forgive me if this topic was covered already I didn't see a thread in paint and body for it so here it is. I have a Redcat Everest 10 and the wheelbase is 13" all the hard bodies I found so far except 1/8 scale are 10 or 11 inches. Has anyone done a more scale/less rc version of the E10? What body did you use?
03-15-2017, 04:02 PM | #2 |
RCC Addict Join Date: Jan 2012 Location: Vancouver
| Re: Long wheel base
There is a couple e10 scale projects, find a body you like then make your wheel base match that instead the other way around. Making new links is easy. Tons of info in here How To: Make your own links |
03-15-2017, 04:51 PM | #3 |
Pebble Pounder Join Date: Jan 2017 Location: Boone
| Re: Long wheel base
I think some of the d110 hard body's are close to your wheelbase. IIRC around 330mm.
03-18-2017, 08:18 PM | #4 |
| Re: Long wheel base
I think I ran into those d110s. And I've already made some bent rear links so I've got that down. But if I change the length of my truck two inches OA doesn't that create a problem with pinion angles?
03-18-2017, 09:58 PM | #5 |
| Re: Long wheel base
When you adjust the lower links, you should do the uppers too. And make them so your pinion angles is correct.
Long wheel base - Similar Threads | ||||
Do u think 14.5 is to long of a wheel base. | OCscx10 | General Scale Talk | 11 | 09-03-2011 12:58 PM |
honcho on a small wheel base? and advantage of the long wheel base? | Daddydancool | Axial SCX-10 | 7 | 04-26-2011 06:29 PM |
LWB (Long Wheel Base) Samurai | Just Zach | Axial SCX-10 | 23 | 11-09-2009 06:35 PM |
Long wheel base Cheby body | DirkDigler | Chit Chat | 6 | 10-17-2006 08:32 PM |
Long Wheel Base Scorpion | RocJoc | General Crawlers | 2 | 12-27-2005 10:08 AM |
