04-14-2017, 08:29 AM | #1 |
Rock Crawler Join Date: Mar 2016 Location: HB
| Metallic yellow
Does anyone make a metallic yellow lexan spray paint? I can't seem to find any and am interested in using it for a build. Maybe this explains why I don't see many yellow rigs out there....
04-14-2017, 09:58 AM | #2 |
RCC Addict Join Date: Aug 2013 Location: Missoula
| Re: Metallic yellow
Mercedes has an awesome metallic yellow paint option, Solarbeam Yellow. Sadly, it's a $10k option Not sure if you can find a can of spray to match that, there doesn't seem to be a good paint code for it. |
04-14-2017, 10:42 AM | #3 |
Newbie Join Date: Jan 2015 Location: Trondheim, Norway
| Re: Metallic yellow
Tamiya PS-6 Yellow, i guess. As long as you spray on the inside of the body, the lexan itself will provide a somewhat metallic look.
04-14-2017, 10:59 AM | #4 |
Pebble Pounder Join Date: Feb 2017 Location: SoCal
| Re: Metallic yellow
What if you were to put a couple of thin coats of yellow and then silver underneath? Would the metallic quality of the silver come through? Now I want to experiment...
04-14-2017, 11:17 AM | #5 |
| Re: Metallic yellow
Pete, that's kind of what I'm thinking. The LHS said yellow metallic looks gold but I've seen yellow metallic on real cars. I'm wondering if the only way to achieve it is to mix paint and airbrush(which I've never used) or try some combo of spray cans. It oils be cool if they made a pure metallic spray that you could lay down and then put whatever color you want behind it.
04-14-2017, 11:21 AM | #6 |
| Re: Metallic yellow
I'm tempted to dust the lexan with a metallic gold or silver and back it with the ps6 emil posted about. Unless maslin wants to hook me up with a loan and I'll send the body to my local benz dealership!hahaha
04-14-2017, 03:24 PM | #7 | |
| Re: Metallic yellow Quote:
04-14-2017, 06:57 PM | #8 |
| Re: Metallic yellow
You might try a Tamiya Translucent Yellow PS-42, backed with Tamiya PS-36 Translucent Silver, then Tamiya PS-41 Bright Silver. Try it first on a test piece so you don't ruin a new body, and make sure each coat has had time to cure, or it will blend. The yellow on my SCT, is Tamiya PS-6 Last edited by Mike Flea; 04-14-2017 at 07:02 PM. |
04-14-2017, 07:06 PM | #9 |
| Re: Metallic yellow
Thanks mike. I'm working on a test panel right now with some paints I have laying around to see how it looks but I hadn't thought about trying the translucent paints.
04-26-2017, 02:03 PM | #10 | ||||
04-26-2017, 02:34 PM | #11 |
| Re: Metallic yellow |
04-26-2017, 06:57 PM | #12 |
| Re: Metallic yellow
Thanks Nate, I don't know about hot, but you sure need sunglasses when looking at it outside in the sunlight, makes it easy to spot on the track.
04-29-2017, 06:54 PM | #13 |
Rock Crawler Join Date: Oct 2009 Location: Upstate NY
| Re: Metallic yellow
I painted the Promarket Merc DTM touring with clear or transparent Yellow first then followed it with bright metallic silver. Turned out as very nice true metallic color. I have some pics somewhere.
Metallic yellow - Similar Threads | ||||
Question about backing metallic paint | Smonkman | Paint and Body | 6 | 03-25-2015 09:49 AM |
Pactra Lexan Paint - Black - Yellow - Metallic Blue | y2kgtp | Vendors Paint and Body | 0 | 03-18-2010 04:57 PM |
metallic grey paint | punkuup5150 | Paint and Body | 11 | 12-19-2009 02:39 PM |
metallic brown paintjob? | adale4130 | Paint and Body | 11 | 10-26-2009 07:49 PM |
