Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Paint and Body
Thread: painting help
Old 01-28-2007, 06:41 PM   #1
Default painting help
I have a new lexan body that I would like to two tone. White top and yellow body. What is the procedure for painting white and other colors? Is it white first, then the other color? or is it the primary color, then the white?
Thanks in advance.
hvydty1 is offline   Reply With Quote
Old 01-28-2007, 06:58 PM   #2
Team *
62PYRO's Avatar
Darker colors first when painting from the inside.
62PYRO is offline   Reply With Quote
Old 01-28-2007, 07:52 PM   #3
10-4, Thanks.
Old 01-29-2007, 12:22 PM   #4
Default Dark First
When painting inside out, I always paint dark colors first, then paint the light colors. If I am going to paint any white, I do all the other colors first. Then I paint the white, and underlay everything with white. Hope this helps. Good luck.
rcnut38 is offline   Reply With Quote
