06-05-2017, 05:51 AM | #1 |
Quarry Creeper Join Date: Dec 2015 Location: Norway
| PET plastic body -paint
I've got a body made of PET plastic that i want to use, but don't know wich paint to use. Does the PET plastic require other types of paint, or is it possible to use Tamiya lexan paint?
06-05-2017, 07:32 PM | #2 |
| Re: PET plastic body -paint
Is that a soft plastic, like what you might find a toddler's toy made out of?, If it is, scuff the surface and you should be able to use the Krylon for plastics spray paint.
06-06-2017, 03:19 AM | #3 |
Same plastic as in some bottles.
06-06-2017, 06:48 PM | #4 |
| Re: PET plastic body -paint Hopefully not the kind made out of corn...it might decompose in the middle of a comp, Seriously, just scuff the surface with 200 grit sandpaper or a green pad, and paint. Tamiya paints are a bit pricey, you might be able to get away cheaper using the Krylon Fusion paint. I also suggest you try it in an inconspicuous spot on the body to make sure it'll work, and give it a day or 2 to cure. |
PET plastic body -paint - Similar Threads | ||||
How can I remove rattle can paint from plastic.. | KustomKreeper8606 | Paint and Body | 4 | 03-03-2013 11:32 AM |
Plastic Wheels paint | major94 | Paint and Body | 8 | 01-15-2010 08:27 PM |
Anybody paint plastic bodys | aftershock1 | Paint and Body | 1 | 07-12-2009 08:27 AM |
Real complaint or whine, striping paint on hard plastic body | Rat1 | Paint and Body | 4 | 03-24-2007 09:27 PM |
Best paint for plastic!!! | 90DEGREES | General Crawlers | 4 | 11-22-2005 08:08 AM |
