Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Trimming front wheel wells on Tamiya Hilux body
Old 05-17-2017, 05:45 AM   #1
Default Trimming front wheel wells on Tamiya Hilux body
Does anyone have any tips on neatly trimming the front wheel wells on a Tamiya Hilux cab? I need to trim the entire arch of the wheel wells.
I'm not exactly sure how much I need to trim. I'll have to trim a little, set the body on the chassis and check it. My biggest issue is keeping both wheel wells the same.
I was thinking about using a drum sanding bit on a Dremel and just slowly sanding the wheel well.
Any help or input would be appreciated!
Sent from my modded Motorola Star Tac flip phone.
2-shot is offline   Reply With Quote
Old 05-22-2017, 08:05 PM   #2
Default Re: Trimming front wheel wells on Tamiya Hilux body
I used a Dremel tool with a cut off wheel, then finished with a sanding drum. Pencil lines where I wanted to cut.
lonleycreeper is offline   Reply With Quote
Old 05-23-2017, 12:53 AM   #3
Use a saw..
Odd-M is offline   Reply With Quote
Old 05-23-2017, 03:35 PM   #4
Yeah I'd use the cut-off / sanding drum and go really slow. You can use string but it's a pain to cut non-straight lines with string and no guide.
Highmark is offline   Reply With Quote
Old 07-18-2017, 12:57 AM   #5
I like any decent brand of curved and or straight body scissors. A new pair especially cuts tamiya hard bodies pretty easily and leaves a pretty clean edge. Easy to sand and clean up.
Plus you have precise control, zero chance of it catching and cutting too far or running across places you don't want scratches.
AJames is offline   Reply With Quote
Old 07-18-2017, 06:53 AM   #6
Moderator
JatoTheRipper's Avatar
Get yourself a good set of both straight and curved lexan scissors. For round wheel wells I bought a large sanding drum set on eBay for my drill. The smaller ones work on my Dremel. They are great and the set was only about $20 shipped.
Mine looks like this.
http://www.ebay.com/itm/NEW-45pc-San...8AAOSw6DtYTPdF
Trimming front wheel wells on Tamiya Hilux body - Similar Threads
hilux trimming joenitro Paint and Body 3 07-26-2011 05:33 AM
wheel rubbing on front of hilux j4k3 Axial SCX-10 5 08-08-2010 12:05 PM
