Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Paint and Body
Like Tree10Likes
Thread: Excellent Painting Guide/How-To
Old 09-14-2011, 01:37 PM   #41
painting metal? Should i sand,primar then paint or sand then paint?thanks
chicostaxxs007 is offline   Reply With Quote
Old 10-18-2011, 10:37 AM   #42
lexan paint is expensive.
I use transparent Lexan Paint
and after that I can apply my inexpensive paints.
I always paint the inside.
Werner7 xr10 user
werner7 is offline   Reply With Quote
Old 10-30-2011, 04:54 PM   #43
I was on ebay the other day and found some tape called PolyMode Tape. It comes in A length of 12 Feet and peels into triangular strips for painting Camoflauge. I am painting today and will put some pics up later.
rockpanda is offline   Reply With Quote
Old 10-30-2011, 05:17 PM   #44
The tape is very helpful! I just put it on the car in a random pattern, painted green and black then took the tape off and painted brown and white! looks amazing! Ill post up some pics soon.
Old 10-30-2011, 05:27 PM   #45
Hope this Works.... Only the front half, Tray is still dryingClick the image to open in full size.
Old 11-03-2011, 07:15 PM   #46
is it just me, or does the link not work anymore?
asian195 is offline   Reply With Quote
Old 11-13-2011, 09:55 AM   #47
Originally Posted by wedjim View Post
Fresh painted Crawler bod.
...Jim
W.E.D.
www.wedjim.com
how do you paint the thin silver/chrome lines in between the colored 'spikes' on this body? Or are they an applied pinstripe (if so, who makes it?)? Great job on this body!
DiggyStyle is offline   Reply With Quote
Old 11-20-2011, 06:12 PM   #48
I can't get the link to work. Can someone redirect me please???
mamcleo is offline   Reply With Quote
Old 11-20-2011, 06:25 PM   #49
I read and figured it out.
Old 11-28-2011, 06:33 AM   #50
The link is not working....
knobbytrav is offline   Reply With Quote
Old 12-02-2011, 02:04 AM   #51
Thumbs up
Link for those arriving late to the party (like me):
http://web.archive.org/web/201007222...m/ken/faq.html
kitsched is offline   Reply With Quote
Old 12-19-2011, 01:33 PM   #52
Default Re: Excellent Painting Guide/How-To
So you paint the inside of the body. Damb I new I was doin something wrong
Lincoln is offline   Reply With Quote
Old 01-30-2012, 08:09 PM   #53
offroad1911's Avatar
I cant get that link to work for me. How about pouring the paint into the body and swishing it around and just pour out the excess.
offroad1911 is online now   Reply With Quote
Old 02-20-2012, 10:10 AM   #54
Good advice!
F350white is offline   Reply With Quote
Old 02-20-2012, 08:42 PM   #55
i just learned that if you soak a body in Dot 4 you can remove paint!
comp pro is offline   Reply With Quote
Old 02-22-2012, 09:22 AM   #56
What primer and paint do you guys recommend for hard bodies.
Archangel is offline   Reply With Quote
Old 03-27-2012, 07:47 PM   #57
I use tamiya primer. Regular primer for painting hardbody and tamiya fine primer for painting chrome parts.
adbradwell is offline   Reply With Quote
Old 04-25-2012, 12:21 AM   #58
I'm a scale noob, but on my full size rig, on bare metal I de-grease, apply a rust preventitive like POR-15, prime then paint. On previously painted metal I just sand lightly then paint. Seems like this would be the same for scaled down parts.
cloudswimmer is offline   Reply With Quote
Old 09-18-2012, 12:12 PM   #59
i know the op is from 2007 but does anyone have a link to a similar how to?
angelicgundam90 is offline   Reply With Quote
Old 12-24-2012, 03:20 AM   #60
Crawlin in the Rainforest
oo C64 oo's Avatar
I used to use actual petrol in the 80's to strip paint of my lexan shells. It still required a fair bit of scrubbing, but did enable a body to be re-used. Ahhh, those were the days when I was on pocket money lol! Also if you do take this path,do it outside & make sure you wear a mask for the fumes, it takes roughly 30 minutes of scrubbing to strip all the paint off.
oo C64 oo is offline   Reply With Quote
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
