10-24-2017, 08:59 AM | #1 |
Newbie Join Date: Aug 2017 Location: Atlanta
| Toyota Sr-5
I’m looking at getting this body and I would like to know how I can mount the body without cutting a slot out on the bed for shock mount clearance. I don’t want to loose flex/ switch to cantilever. Any suggestions?
10-24-2017, 11:43 AM | #2 |
| Re: Toyota Sr-5
Some more info would help, such as the truck you. I have mine on an scx10 and I have regular shock hoops on mine.
10-24-2017, 12:56 PM | #3 |
| Re: Toyota Sr-5 |
10-24-2017, 06:39 PM | #4 |
Quarry Creeper Join Date: Aug 2017 Location: KY
| Re: Toyota Sr-5
I just put one of these bodies on my youngest son'a scx10 chassis. The stock shock hoops sit up inside the fake tool box (or whatever it's meant to be) in the bed. Having said that, I'm not sure of the difference (if any) in the scx10 - scx10.2 chassis/shock hoops. On the scx10 chassis, the body has a lot of rear over hang that doesn't allow running a stock rear bumper (it would sit way up under the bed). I'm still trying some things to work out a rear bumper for him. |
10-24-2017, 10:43 PM | #5 |
Rock Crawler Join Date: Mar 2017 Location: Rubicon Trail
| Re: Toyota Sr-5
I mounted the shocks from the screws on the lockouts on my SCX10 II to a simple bracket I fabbed out is aliminum sheet on the crossmember in between the shock hoops like the TF2 and I lost very little clearance/ articulation Sent from my iPhone using Tapatalk |
10-25-2017, 07:57 AM | #6 |
| Re: Toyota Sr-5 Just a simple bracket fabbed out of some aluminum sheet mounted to the two holes on the rear crossmember Sent from my iPhone using Tapatalk |
10-26-2017, 08:51 PM | #7 |
Newbie Join Date: Aug 2017 Location: QC, Canada
| Re: Toyota Sr-5 I have the same combo. No cutting needed. The extra body mount posts included if you have the kit version are a direct alignment with the shell's hole dimples (if you choose to drill the body). As easy to install as the stock shell. Assemble front & back bodies first then treat as a single unit when mounting on frame. (I didn't... I test-fitted cab and bed separately, I thought it wouldn't fit and began to cut the bed... ) |
10-27-2017, 12:38 PM | #8 | |
Rock Crawler Join Date: Oct 2009 Location: Danish badlands
| Re: Toyota Sr-5 Quote:
In the end found out it was mainly my tires that was to blame for the poor drive with the K5 body, but i have moved on to SCX 10 II and put the TF2 on the back burner. | |
Toyota Sr-5 - Similar Threads | ||||
Toyota Hilux VUCK and Toyota FJ40 AWESOME VID | HOONIGAN | Scale Videos! | 0 | 06-01-2016 04:08 PM |
Toyota project.... but which Toyota. | utieh | Axial SCX-10 | 2 | 11-20-2009 06:12 PM |
