12-24-2017, 07:41 AM | #1 |
RCC Addict Join Date: Jan 2010 Location: Barboursville, WV
| Scale rock damage?
What's the best way to accomplish this? I've seen people heat up the body and use a spoon to make dents so I'm assuming the same concept would work. If I heat the body and press it against a rock or two, would that do the trick? Sent from my HTC6545LVW using Tapatalk |
12-27-2017, 07:12 AM | #2 |
Newbie Join Date: Nov 2017 Location: MERRITT ISLAND
| Re: Scale rock damage?
I'd bet it would, heating the body is the only way I've seen this done
12-27-2017, 07:14 AM | #3 |
RCC Addict Join Date: May 2015 Location: Price Twp.
Visit youtube and search Scale War Machines. Wealth of knowledge about doing realistic weathering and damage.
12-27-2017, 08:04 AM | #4 |
Rock Stacker Join Date: Dec 2015 Location: Finland
Apply heat from the inside and when you see plastic turn glossy stop heating and immediatly press against some surface. Keep the damage realistic: Body panels are more rigid from the sides and open the gaps between the panels and doors etc with dremel. Here's some photos of my damaged builds. |
12-27-2017, 07:32 PM | #5 |
I assume you're using a hard body. You can do it to a lexan body too, but you can ruin the lexan body faster than a hard body, as it will have a lower melting point.
12-27-2017, 08:24 PM | #6 |
I joined the Band! Join Date: Mar 2009 Location: Right Here
I need to replicate this... Sent from my iPhone using Tapatalk |
12-28-2017, 12:05 AM | #7 |
There is also another method to try. In this method you dremel out the middle/center part of panels, leaving only the frames. Then you cut thin metal or foil pieces over the panels and glue them in to cover the holes. Then just paint and drive recklessly to get some damage! Very realistic as the metal bends and the plastic frames work as understructure. I've seen build somewhere with this method and if I find it I'll post it here! |
Scale rock damage? - Similar Threads | ||||
how much damage will be done? | freakofnature | Electronics | 5 | 06-20-2012 08:26 AM |
damage? | m3kan1k | Axial SCX-10 | 4 | 03-11-2009 01:40 PM |
Scale 4x4 R/C Official Summer Scale Comp, Little Rock City, AL | Jugg2Driver | Competitions | 0 | 02-28-2009 09:09 PM |
More Damage | cwkoehler | General Crawlers | 1 | 03-23-2008 08:37 PM |
Course damage | Cloak | Competitions | 9 | 06-11-2007 11:50 AM |
