12-28-2017, 08:13 AM | #1 |
Rock Crawler Join Date: Jun 2017 Location: Land of burning couches
| What kind of velcro?
I've tried several different kinds. None seem to be cutting the mustard to holding bodies on. I expect the body to pop off on a good hard roll, but I'm talking a flop and they come off. What do you all use? (links or pics helpful) and go...
12-28-2017, 08:15 AM | #2 |
| Re: What kind of velcro?
I used the industrial or heavy duty Velcro on my B5 body when I raced.
12-28-2017, 10:13 AM | #3 |
I use industrial strength stuff. About a 1"by 2" rectangle on the chassis side and a 2" by 2" square o the body side. I did find you have to let the velcro set up... Meaning apply it to the surface, then wait a couple hours before attempting to use it as intended. And temperature has a lot to do with it. Velcro does not like to be applied when it is cold. |
12-29-2017, 07:28 PM | #4 |
Quarry Creeper Join Date: Aug 2017 Location: KY
3M Dual Lock is the best Velcro I’ve ever used. Find it on amazon or ebay
12-29-2017, 11:51 PM | #5 |
Rock Crawler Join Date: Apr 2006 Location: Folsom, CA
This is what you're looking for. Comes in clear and black and its the same pattern on both sides. Not like your standard velcro with one soft side and one prickly side. |
12-30-2017, 07:57 AM | #6 |
Dual lock..... hands down. You can find it at Home Depot. Hang up and Drive |
12-30-2017, 09:33 AM | #7 |
Quarry Creeper Join Date: Nov 2013 Location: Omaha
Yep that’s the stuff! Sent from my iPhone using Tapatalk |
01-08-2018, 09:28 AM | #8 |
| Re: What kind of velcro? |
01-10-2018, 09:04 AM | #9 |
I wanna be Dave Join Date: Dec 2016 Location: san diego
yup we use that in the navy to hold our monitors and junior sailors to things so they don't slide around in high seas. whenever i use that stuff, when I'm done i look at my work and quote the boondock saints. "whea you goin? NO WHEA." |
01-28-2018, 10:28 AM | #10 |
Quarry Creeper Join Date: Jan 2016 Location: Southampton
That velcro is awesome. I did have problems with the glue side holding. I didnt realize if you wait a bit it holds better. I superglued it to my body and it works awsome. Definately need the industrial grade hook and loop. |
01-28-2018, 10:51 AM | #11 |
Newbie Join Date: Nov 2017 Location: USA
3M Dual Lock is really good. Anything you can get in a large sheet could work. Try using more surface area to get a better connection. If you get a large sheet you can cut larger patches and even add small patches in new places.
02-04-2018, 11:56 PM | #12 |
Quarry Creeper Join Date: Aug 2017 Location: Surface of the Sun
Yup, we use that stuff in the Air Force too...... to keep Flyboys from either leaving shit on the Jet, or forgetting to take stuff with them, ON the Jet!!!! Actually, the upper Stratosphere Pilots (like Dad), had to wear Spacesuits, similar to Gemini Astronauts wore. The Gloves were so thick and stiff, that Velcroing vital items to their Suit Legs, made it far easier to grab stuff at altitude! Yeah........ It's strong enough for our 1/10th Scale Rigs! |
02-05-2018, 10:42 AM | #13 |
and then you can throw those pilots at a carpet wall and they stick!
What kind of velcro? - Similar Threads | ||||
Need Velcro Staps? | RcBro | Vendors Electronics | 0 | 08-22-2011 06:15 PM |
What velcro | 0lllllll0 | General Crawlers | 13 | 03-14-2011 08:29 PM |
question about velcro | NeXt559 | Paint and Body | 10 | 02-05-2010 11:08 PM |
Velcro on paint | Troystr68 | Paint and Body | 4 | 07-11-2007 06:33 PM |
Should I drill it or velcro it??? | bluonyx | Tamiya Txt-1 and Juggernaut | 3 | 12-13-2006 12:15 PM |
