03-19-2018, 07:54 PM | #1 |
Rock Stacker Join Date: Apr 2017 Location: North GA
| Any tips for cutting door jam lines in mask?
So I'm about to paint a body. I've sprayed my liquid mask and it's drying overnight. I would really like to cut the door lines so I can paint them black. Any tips and tricks on doing this? Thanks.
03-20-2018, 05:46 PM | #2 |
| Re: Any tips for cutting door jam lines in mask?
Do the door lines on the outside with a Sharpie fine tip permanent black marker
03-20-2018, 09:53 PM | #3 |
Rock Stacker Join Date: May 2017 Location: Alberta
| Re: Any tips for cutting door jam lines in mask? |
03-26-2018, 10:01 AM | #4 |
I THIRD the fine line Sharpie technique. It's simple to do and easy to touch up as the lines fade. I think the problem with masking for them is that the lines are going to be so fine, it's going to be nearly impossible to get a good accurate mask, particularly around compound corners and curves. Then, assuming you were able to get them masked, there's always the dreaded paint bleed on top of that.
04-04-2018, 06:01 PM | #5 |
Quarry Creeper Join Date: Jan 2012 Location: winder, ga
after paint I use a small amount of black wash on the body lines; gives a nice subtle detail that doesn't overpower like a perfect black line.
04-08-2018, 06:10 PM | #6 | |
Quarry Creeper Join Date: Aug 2017 Location: KY
| Re: Any tips for cutting door jam lines in mask? Quote:
I paint on the outside but would like to add the body seams effect, without overpowering as you describe. | |
04-08-2018, 07:14 PM | #7 | |
Rock Crawler Join Date: Nov 2014 Location: Dells
more = better when it comes to liquid mask. Too thin and you won't be able to peal it off. | |
04-10-2018, 08:34 PM | #8 |
I posted the below in the weathering sticky at top of the page, but not sure how much traffic that sees, so pasting below in this active discussion........ I ordered the exact black paint as in OP’s initial post. Want to black wash a lexan body to get door / body seam lines effect. Can someone confirm I am on the right track? Also, would lightly scoring the seams with a razor blade or small awl help the effect? |
04-10-2018, 09:55 PM | #9 |
If you are of steady hand, I'd think a light scoring of the lines would definitely be beneficial.
04-11-2018, 01:47 PM | #10 |
04-11-2018, 05:56 PM | #11 |
04-17-2018, 05:16 AM | #12 | |
Rock Crawler Join Date: Oct 2015 Location: Kristiansand
(but I'm a novice and crap at painting, so I really shouldn't give advice). Sent from my SM-G930F using Tapatalk | |
05-04-2018, 07:53 PM | #13 |
@tjohanne - agreed! Thin line black Sharpie and mistakes or outside the lines are easily remedied with isopropyl alcohol wipe.
Any tips for cutting door jam lines in mask? - Similar Threads | ||||
Any tips on how to cut the cutout for the mask? (PSA: It is difficult!) | Ambis | Axial SCX10 II | 16 | 06-14-2016 08:37 PM |
door lines and panel lines (sharpie alternative) | heinie_21 | Paint and Body | 10 | 12-23-2011 08:32 AM |
black door lines, need help | LS1Armyboy | Paint and Body | 9 | 07-12-2010 10:35 PM |
tips for cutting foams | minor_threat | Tires and Wheels | 34 | 02-15-2009 02:55 PM |
Neat way to define door lines, etc... | Zod Rhombus | Paint and Body | 4 | 02-18-2008 11:08 AM |
