05-19-2018, 01:47 PM | #1 |
RCC Addict Join Date: Feb 2016 Location: Princeton, North Carolina, USA
| Shoo goo to metal?
Anybody ever tried cementing plastic to aluminum with Shoo Goo or E6000? Sent from my SM-G930R4 using Tapatalk |
05-19-2018, 02:13 PM | #2 |
RCC Addict Join Date: Jun 2017 Location: Canada
| Re: Shoo goo to metal?
I used goop glue to put a metal washer on shoelaces for my Seatbelts. That type of glue works on everything. Sent from my Nexus 6 using Tapatalk |
05-19-2018, 02:22 PM | #3 |
| Re: Shoo goo to metal? |
05-19-2018, 04:20 PM | #4 |
Yep, used some E6000 to attach an aluminum bracket to an ABS hardbody for a micro crawler last year. Still holding strong.
05-19-2018, 04:35 PM | #5 |
| Re: Shoo goo to metal? Thanks! I wasn't sure how dependent the adhesive properties would be on ability to dissolve/fuse the two materials. I think I'm going to try it then.
05-19-2018, 04:45 PM | #6 |
I used E6000 to attach a piece of flat steel to the bottom of a hard body to act as a magnetic surface for the mount magnets. Worked very well.
05-19-2018, 04:53 PM | #7 |
05-19-2018, 05:58 PM | #8 |
RCC Addict Join Date: Aug 2013 Location: Calgary - in the Great White North
I used E6000 to mount magnets to hold the body on. Sticks like glue!
05-19-2018, 06:23 PM | #9 | |
| Re: Shoo goo to metal? Quote:
Just E6000'd the PCB board I used as the velcro base for the front body mount of my current build to the aluminum body posts (work donates a lot of handy things for RC's). Didn't hurt that I screwed up and drilled the pass-thru holes perfectly so it was already a tight fit, but yeah, it seemed to work just fine! | |
06-05-2018, 09:56 PM | #10 |
Rock Stacker Join Date: May 2018 Location: Los Angeles
I used shoe goo to glue magnets together.
Shoo goo to metal? - Similar Threads | ||||
Shoo-goo ... Velcro ... Double stick tape ??? | Frank211 | Newbie General | 2 | 03-16-2018 12:06 PM |
Shoo goo | dentguy55 | Axial SCX-10 | 18 | 08-13-2014 08:09 AM |
Superglue + Shoo Goo OK to bond Styrene? | RyanV45 | Paint and Body | 3 | 02-04-2012 05:56 PM |
Shoe Goo | red jim | Tires and Wheels | 9 | 01-30-2008 07:18 AM |
Is Shoo Goo the same as silicone. | Tronk | Electronics | 22 | 11-21-2006 04:30 AM |
