Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Rmoving sandng dust
Old 08-06-2018, 07:46 PM   #1
Default Rmoving sandng dust
I have a quick question regarding sanding primer and paint coats on hard bodies. What should I use to remove the sanding dust before painting another layer? Wet/dry cloth? Tack cloths?
delche is offline   Reply With Quote
Old 08-06-2018, 11:38 PM   #2
Default Re: Rmoving sandng dust
I'd start with a tack cloth then get the cleaner specifically for this kind of job and wipe it down with that. Duplicolor now offers them in a one time use packet like a wet wipe.
BJoe is offline   Reply With Quote
Old 08-07-2018, 06:14 PM   #3
Personally, I'd wash it, and either use an air gun to blow dry it or give it 24 hrs to dry before painting. Unless you're meticulous, getting a tack rag into all the cracks and crevices of a plastic body, is almost impossible.
Mike Flea is offline   Reply With Quote
Old 08-07-2018, 07:37 PM   #4
Thanks for the information!
Old 08-08-2018, 05:28 PM   #5
Like Mike Flea said. Wash it. Thoroughly dry it, or let it air dry for a day. I use SimpleGreen because I like the de-greasing properties of it. But, Dawn dish soap or similar would also work well. Additionally, I usually do a quick "prep wipe" using a clean, soft, lint-free wipe with some isopropyl alcohol. It pretty much flash dries, so it's great to use just prior to shooting paint, and it helps ensure you've gotten all the oil, dirt and grease residue.
Also, don't forget to wear latex gloves when handling it prior to and during painting. Keeps the oils from your hands contaminating things, and it keeps the over-spray off your hands, so it's TWOFER!
mewalsh100 is offline   Reply With Quote
Old 08-08-2018, 06:31 PM   #6
Blow off with air, Tack cloth, followed by a complete washing then dry with micro fiber towel.
Code54 is offline   Reply With Quote
Rmoving sandng dust - Similar Threads
From Dust Duuuuuuuude Chit Chat 12 08-07-2011 08:30 PM
Dust to glory crash Chit Chat 4 12-03-2010 06:18 PM
collecting dust backfold HPI Wheely King 4 11-14-2008 07:11 AM
Another one bites the dust! camel_rc Electronics 2 02-28-2008 12:21 PM
