02-18-2019, 02:31 PM | #1 |
RCC Addict Join Date: Mar 2011 Location: easton
| Airbrush setup
I am thinking about getting an airbrush to paint both lexan and hard bodies but I have little no experience with with airbrushes so I’m looking for a good complete setup, preferably under $3-400, and as quiet as possible Sent from my iPhone using Tapatalk |
02-18-2019, 02:55 PM | #2 |
RCC Addict Join Date: Nov 2014 Location: Nowhere
| Re: Airbrush setup
If I was to get into it I'd probably copy my friend's setup, he has a Badger Patriot 105, generic 1/5 HP compressor, hose and accessories and the cost is only around $180. Quiet is kind of relative, the compressor isn't on 100% of the time but when it does come on it's not terribly loud as long as its stable on carpet or something. Basically these two: https://www.amazon.com/dp/B002W84GTO..._JLYACbJQ1PC29 and https://www.amazon.com/dp/B005H3CBXO..._4LYACbH22SMZ9 |
02-18-2019, 05:30 PM | #3 |
| Re: Airbrush setup
I just bought a Badger 105 Patriot to start painting bodies. I think the brush was around $80. As for air compressors, you should get one with a tank for best results. Those little "airbrush" compressors don't have tanks. I have a Husky, quiet, aluminum tank air compressor (rebranded California Air) that I got on clearance. It was a steal at half price on clearance. Some Home Depots stock California Air. If you want quieter you're going to have to spend big money. https://www.homedepot.com/s/california%2520air?NCNI-5 |
02-18-2019, 06:12 PM | #4 |
Rock Crawler Join Date: Aug 2011 Location: Baton Rouge
| Re: Airbrush setup
What kind of paint are you using to paint hard bodies ?
02-18-2019, 06:27 PM | #5 |
| Re: Airbrush setup
I really need to gather up the courage to get paint and start airbrushing.
02-18-2019, 08:57 PM | #6 |
Slow is the new Fast Join Date: Nov 2013 Location: Winterpeg
| Re: Airbrush setup
I am using the Iwata Neo airbrush and a mini compressor that come together in a kit. So far the mini compressor has worked to my satisfaction. The airbrush works great as well... when it is not clogged with paint Keeping the brush clean has been a meticulous effort in my experience. It needs to be thoroughly cleaned with each use. Cant say I would recommend the Iwata Neo for that reaason
02-19-2019, 05:57 AM | #7 |
| Re: Airbrush setup
If you want to learn more about particular models of airbrushes, this guy's site is awesome. And he's well respected on some of the airbrushing/modeling forums. https://sites.google.com/site/donsairbrushtips/ |
02-19-2019, 07:26 AM | #8 |
Pebble Pounder Join Date: May 2015 Location: UK
| Re: Airbrush setup
Can recommend Iwata airbrushes. Compressors are generally fairly noisy things though. It's worth noting that most airbrushes have their own nuances, and most paints also are happiest to be sprayed at certain pressures and sometimes need to be thinned. It's all fairly easy stuff to find information on. Lexan body painting is an entirely different beast to hard bodies. For hard bodies you can learn about painting by watching almost any model painting video on the internet. All the techniques to painting AFVs or planes, as well as materials also applies to RC hard bodies. For lexan, you need to be a bit more picky about paint. Something like Fascolor or Createx autoair works on both types of body. Almost all paint needs to be thinned though and Don't forget airbrush cleaner. |
02-19-2019, 08:53 AM | #9 | |
I wanna be Dave Join Date: Apr 2010 Location: Oakridge
| Re: Airbrush setup Quote:
Thanks Tim, I saved it to my favorites! Ernie | |
02-25-2019, 04:48 PM | #10 |
Pebble Pounder Join Date: Jan 2019 Location: Douglas, MA
| Re: Airbrush setup
Don’t want to hijack but what kind of paint are you guys using for airbrushing hardbody’s?
04-18-2019, 03:02 PM | #11 | |
Rock Stacker Join Date: Mar 2019 Location: Bothell
Enamels or acrylics should work, with acrylics being more fragile in my opinion (but easier to clean). Either will need a coat of primer. Mr. Surfacer being the best, also in my opinion. | |
04-18-2019, 03:55 PM | #12 |
RCC Addict Join Date: Sep 2017 Location: The OC
| Re: Airbrush setup
PAASCHE. You'll thank me later. |
Airbrush setup - Similar Threads | ||||
Airbrush ?'s | Cajunbrn | Paint and Body | 10 | 11-04-2009 05:11 PM |
Maybe getting an airbrush, need help | Spiftacu1ar | Paint and Body | 2 | 09-04-2009 10:48 AM |
for those of you that airbrush | aftershock1 | Chit Chat | 5 | 03-16-2008 06:26 PM |
