02-18-2019, 08:17 PM | #1 |
Rock Crawler Join Date: Aug 2015 Location: Fort Knox, Kentucky
| Securing a lexan body with velcro?
So I've never used Velcro or any clip/posts system to mount bodies before. Could anyone share some tips or tricks on what to use for a lexan body? I've got a body with an interior I'd like to use and would love to go postless! Thank you. |
02-18-2019, 08:38 PM | #2 |
| Re: Securing a lexan body with velcro?
Use some ring magnets like these (see link). Trim the top off the mount posts so they are 1/4" tall. Glue one magnet to the post and the other to the underside of the body. The post inserted into the magnets keeps it all lined up. The problem with velcro is that it wears out over time and velcro gets pretty nasty in mud. https://www.ebay.com/itm/1-2-x-1-4-x...S!-1:rk:2:pf:0 Last edited by Inspector86; 02-18-2019 at 08:48 PM. |
02-19-2019, 10:06 AM | #3 |
I m also gonna say do the ring magnets on the post. Both lexan bodies . Hang up and Drive |
02-19-2019, 10:14 AM | #4 |
My tip is - don't do it. Velcro will pull off after time. And sometimes it will pull your nice paint job with it. Same goes for magnets. Posts are still the best in terms of functionality.
02-19-2019, 02:11 PM | #5 |
| Re: Securing a lexan body with velcro? I did not think about that! Another option would be to create a hinge mechanism and secure it to the Proline interior then run front body posts. |
02-19-2019, 02:40 PM | #6 |
Prep is your key. Shoe goo and lexan work well together. But if you don’t prep correctly for paint it will lift off in a sheet. You need to scuff the CLEAN lexan. Wash, dry, then scuff. This removes all mold release. Then use a paint that chemically bonds to lexan. Then let paint dry and cure. Then magnets or Velcro. Mine fall and the magnets haven’t failed yet. You must do the clear tape between . I sorta agree with Jato, but it can be done. Hang up and Drive |
02-19-2019, 04:30 PM | #7 | |
| Re: Securing a lexan body with velcro? Quote:
I'm not sure what caused it, but I know it's not worth it, to me, to try again. Body clips are simple and effective. The only time I wish I'd use Velcro or magnets is when I'm taking photos and that is a very small percentage of my day when I'm doing a trail run. I do see others have success with it though. | |
02-19-2019, 05:05 PM | #8 | |
Quarry Creeper Join Date: Dec 2016 Location: Cawston, British Columbia, Canada
Originally Posted by mikemcE - You must do the clear tape between. Mike - can you explain the purpose of the clear tape on top of the magnets please. Thanks. Hang up and Drive | |
02-19-2019, 05:10 PM | #9 | |
Ive found a scotch green pad to scuff works best with a bit of soapy water. I detest clips, so many bodys use a 4mm screw and ProLine caps | |
02-19-2019, 05:16 PM | #10 | |
I put it between when drying overnight, because when I tried the first time without, I pulled one magnet off the body. After they cured, I covered them with clear tape to keep everything tight This was the whole post Bea Last edited by mikemcE; 02-19-2019 at 05:22 PM. | |
02-19-2019, 05:32 PM | #11 | |
02-20-2019, 08:03 AM | #12 | |
Securing a lexan body with velcro? - Similar Threads | ||||
Securing LEDs to lexan/plastic buckets | GRandturk | Electronics | 12 | 08-09-2013 11:36 PM |
Rubicon/any body velcro body mounts | uclabruins89 | Axial SCX-10 | 4 | 07-26-2013 10:12 PM |
Need some advice... Painted lexan body and velcro | Crawl Wonder | Paint and Body | 1 | 09-26-2011 11:17 AM |
How are you guys securing your LED's to Honcho body headlights? | Hordsak | Axial SCX-10 | 10 | 03-24-2010 11:14 AM |
Velcro body mounting | TIMZKRAWLER | Paint and Body | 15 | 07-01-2009 09:13 PM |
