03-24-2019, 06:34 PM | #1 |
Pebble Pounder Join Date: Oct 2015 Location: Fraggle Rock, CO
| First Paint Project: Corsa Gray JK
So, when I bought my used scx10 it came with an unpainted Jeep JK body. It has sat around for acouple years while i thrash the (red)JK body that it had on top. Finally, that body has begun to crack and also, i got the itch for something different. So, I decided to paint the other body i have, rather than get a different model... So, here goes for the test run. My prep includes light scuffing with a scotchbrite pad. Warm water and Dawn wash, followed by a wipedown with 91% Isopropyl Alcohol. So far, things look to be holding well. When i got my truck, the red body had the silly hinge decals, etc. I quickly hand painted the outside of the body to imitate the hinge. For this body, I started with the vents, hinges and accents first, Flat Black acrylic paint.. Sent from my VS987 using Tapatalk Last edited by SurfinStud; 03-24-2019 at 06:47 PM. |
03-24-2019, 06:35 PM | #2 |
| Re: First Paint Project: Corsa Gray JK
After getting all the decals and hinges how I liked, finally came the Body color: Tamiya PS-32 Corsa Gray It still has the outer film on, as I havent put the white backing on yet. Speaking of which, How long do you guy wait until you spray a different color backing onto a tamiya paint? 12 hours? 48+ hours? I'm curious. Stay Tuned, Much more to come including: Light buckets Rock lights Magnet Mounts 1000,3s Dont mind the freshly cleaned hiking socks sprawled out... Sent from my VS987 using Tapatalk Last edited by SurfinStud; 03-24-2019 at 06:51 PM. |
03-25-2019, 11:18 AM | #3 |
Newbie Join Date: Feb 2019 Location: Central Maine
I really like that color, reminds me of the Gulf color scheme. I typically wait 24 hours depending on temp and air conditions. What up with the orange swirls?
03-25-2019, 05:58 PM | #4 | |
| Re: First Paint Project: Corsa Gray JK Quote:
Ah, the gulf color scheme, hadnt thought of that. It is definitely close to that shade of "baby blue." We are around 30 hours since I painted the last coat, i guess i am in the clear for spraying my backing. Sweet! Sent from my VS987 using Tapatalk Last edited by SurfinStud; 03-25-2019 at 06:04 PM. | |
03-25-2019, 09:38 PM | #5 |
Smooth sailing with the backing. I couldn't exactly tell, so, does it make a difference if your "top" coat(body color) is pretty thick? Also, I went ahead and pulled the stickers on the inside of the headlights as the next step is preparing and painting my lexan light buckets~for installation. I am intending on painting those Chrome. I'll research some, but is that common and proper for the headlight buckets? While the the buckets are being sorted; ill source some ring magnets for the hood. Those will be shoegoo'd on before I ream the holes for the rear mounts(clip style) and on top of that, a trip to radioshack for a micro(m.) switch. I'll run the m.switch off the 3S that i'll mount under the hood. The m.switch will be mounted where the (interior)gear shifter should be. I should be able to reach it through the passenger window. Sent from my VS987 using Tapatalk Last edited by SurfinStud; 03-25-2019 at 09:58 PM. |
04-05-2019, 12:28 PM | #6 |
Finally got around to painting the headlight buckets. I'll cut them out and shoegoo them in place tomorrow. Before I goo them in, i will ream out the light holes for LEDs. Easy peasy. Sent from my VS987 using Tapatalk |
First Paint Project: Corsa Gray JK - Similar Threads | ||||
Tamiya corsa grey? | fr8cture | Paint and Body | 4 | 12-01-2014 02:10 PM |
RTR jk gray paint match ? | SkyJacked | Axial SCX-10 | 3 | 07-18-2014 01:29 PM |
gray paint | vito | Paint and Body | 3 | 09-20-2013 10:06 PM |
Polycarbonate gray paint? | toyotatrucks83 | Paint and Body | 8 | 12-19-2011 12:57 PM |
