Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Trx4 with Trail Honcho bed/cage?
Old 05-14-2019, 11:49 PM   #1
Default Trx4 with Trail Honcho bed/cage?
I’ve seen it done, just wondering if anyone that has done it needed to make any nodifications for it to fit.
timboe219 is offline   Reply With Quote
Old 05-15-2019, 06:31 AM   #2
Go Buckeyes!
B-MOW71's Avatar
Default Re: Trx4 with Trail Honcho bed/cage?
I did mount the Honcho & Cage to my TRX-4. Had to modify the bottom of cage to fit over the battery. I currently do not have a pic of the modification, but I can get you a pic later today.
B-MOW71 is offline   Reply With Quote
Old 05-15-2019, 10:14 AM   #3
Thanks Brian that would help me out a lot. Can’t wait to get this build started!
Old 05-15-2019, 07:15 PM   #4
Go Buckeyes!
B-MOW71's Avatar
Here are the pics of the underneath. I am also using the Bowhouse battery tray which sits lower in the chassis. The rear body mount is different than the stock Honcho cage, so it’s up to you how you want to mount it. I used the outside scrap lexan piece of the cage lexan instead of the inner lexan that is supposed to be used. In the last pic, you can see the rear body mount. I just screwed them into the rear chassis brace. I hope all this makes sense!
Old 05-15-2019, 08:10 PM   #5
dezfan's Avatar
I used the Ascender cage on my GEN8.
dezfan is offline   Reply With Quote
Tags
trail honcho, trx4
Trx4 with Trail Honcho bed/cage? - Similar Threads
Attaching the Trail Honcho Cab without cage/bed? KellyC Newbie General 1 04-04-2017 12:47 PM
