Is there a Paint that mimics bedliner ? I’m looking for something that gives the texture appearance of line x or rhino liner etc . Anyone ever use anything like this on top of a lexan shell and if so any tips on application ? |
Re: Is there a Paint that mimics bedliner ? I use rustoleum bedliner spray, painted a full axial cherokee outside the body and it holds very well Sent from my iPhone using Tapatalk |
Re: Is there a Paint that mimics bedliner ? Excellent ty . Is it textured ? Can you post a pic ? |
Re: Is there a Paint that mimics bedliner ? Its actually bedliner https://uploads.tapatalk-cdn.com/201...f084d18bff.jpg Sent from my iPhone using Tapatalk |
Re: Is there a Paint that mimics bedliner ? Quote:
Re: Is there a Paint that mimics bedliner ? Yeppers Rustoleum bed liner. Adheres well to lexan, finish is close to looking scale.https://uploads.tapatalk-cdn.com/201...4c13e3fa30.jpg Hang up and Drive |
Re: Is there a Paint that mimics bedliner ? The top of my 4runner is rustoleum bed liner has some good texture I’ve used it on everything. Seems to stick well to lexan as well. https://uploads.tapatalk-cdn.com/201...82dac7c086.jpg Sent from my iPhone using Tapatalk |
Re: Is there a Paint that mimics bedliner ? I’ve also used the Rustoleum bed liner on parts of my rigs. Make sure you prep what you’re going to spray really well. With lexan, scuff the area up with some scotch brite pad or some steel wool. Then wipe down with isopropyl alcohol. Ready to spray. |
Re: Is there a Paint that mimics bedliner ? I've used Rustoleum "stone finish" in the past, it gives a believable texture that passes for bed liner. https://images-na.ssl-images-amazon....3lPNL._AC_.jpg |
Re: Is there a Paint that mimics bedliner ? I too have used the Rustoleum bed liner spray on all of my bodies with great success. Some of them are at least ten years old, and it has never chipped or flaked off. Usually I've scuffed the area I'm applying it to really well, but on my most recent body I just cut the overspray film around the bed area, and gave it a quick light coat of Tamiya black, and then applied the rustoleum bed liner. So far it is holding up just fine. I'll add that distance is your friend when spraying the Rustoleum, it comes out fast and thick as it is meant to cover large areas of a pickup bed. So if you're not careful it can build up way to thick and run on the small area you'll be painting on a lexan shell. |
Re: Is there a Paint that mimics bedliner ? i sprayed some on my sliders for the 79 ford. HAD pics but tinypic went kaput and i lost the entire thread. but yes, rustoleum bed liner thirded. |
Re: Is there a Paint that mimics bedliner ? I use duplicolor truck bedliner paint, and I've found it to work extremely well. It holds up very well, and looks perfect. I've used it in the bed of my basher bodies with no base coat and it doesn't chip off. https://live.staticflickr.com/4678/2...e58c835a_c.jpg On my Gen8, I laid down a couple coats of black Duratrax body paint for adhesion, then sprayed the Duplicolor over that. That truck has taken some tumbles and the paint still looks 100% perfect. https://live.staticflickr.com/7861/4...6b19c6a1_c.jpg https://live.staticflickr.com/4804/3...0c833591_c.jpg |
Re: Is there a Paint that mimics bedliner ? rustoleum has textured paint. really duplicates the bed liner look. |
Re: Is there a Paint that mimics bedliner ? I used the rattle can bedliner spray I got from O'Reilly's. I think it was the duplicolor. I sprayed it on the outside (obviously) and it worked well. I suggest you run a hobby knife around the edges before you unmask though...https://uploads.tapatalk-cdn.com/201...709bb52862.jpg |
Re: Is there a Paint that mimics bedliner ? @Jim85IROC - Love the clean look of that Scout in black and white. Textured black roof was the perfect accent. Nice job! |
Re: Is there a Paint that mimics bedliner ? I used flex seal on the bed of my vs410 pro and love the way it looks. It took a few days to harden up though. |
