Window tint - pros and cons I'm considering window tint on my 66 C10 honcho. I know it's mostly an aesthetics choice, but I'm brainstorming to help with my decision before I proceed as this would be the final paint step before I remove the overspray film. Any thoughts? Thanks! Here is an older picture just to give you an idea of my paint scheme: https://uploads.tapatalk-cdn.com/201...d8839d2243.jpg Sent from my SM-G973U using Tapatalk |
Re: Window tint - pros and cons I did tint on my 4Runner, because I wasn't planning on doing an interior and didn't want to just be looking at all the guts of the chassis. Before: https://i.imgur.com/Va4Ay0x.jpg After: https://i.imgur.com/csqiAyp.jpg |
Re: Window tint - pros and cons Thanks for the before and after shots - nice rig! "thumbsup" |
Re: Window tint - pros and cons https://uploads.tapatalk-cdn.com/201...04f532e43d.jpghttps://uploads.tapatalk-cdn.com/201...90c33ecc38.jpg I used window tint film from the automotive world. Get it free from a local tint shop’s scraps Hang up and Drive |
Re: Window tint - pros and cons That's a good idea too! "thumbsup" |
Re: Window tint - pros and cons The more I think about it I'm just going to pull the masking/film and see how I like them clear. If I decide later I want to tint I can always mask the body using saran wrap and masking tape to protect from over spray. |
Re: Window tint - pros and cons If you use Tamiya's Smoke Tint, make sure your body color is backed, especially if its a light color. The first time I used it, I did it on a yellow body w/o backing and ruined it. |
Re: Window tint - pros and cons what do you back the body color with silver or white? |
Re: Window tint - pros and cons Quote:
Most important thing you can do is hit some test scraps of lexan with what you're thinking on using. It's really the only way to know for sure how somethings going to look for sure. Basic reds, blues, greens, etc are good examples. Any of those colors might look fine regardless of what color you back them with BUT that same color backed with white/ silver/ black are all going to look different... sometimes minimally different... sometimes drastically different. Also it will matter how many color coats you lay down before applying the backer. Seriously... do some test scraps to be 100% sure how it's going to look. |
Re: Window tint - pros and cons mikemcE & Stormin2u- That's a great suggestion. I think I'm going to use that next time. One thing that I don't care for with the Tamiya window tint is that it looks kinda "dirty" or something along those lines, if you spray it just a little too heavy. It's obvious from the pic above that the tint-film indeed looks more realistic. |
No problem. FYI make sure inside is spotless and degreased. No tape residue or anything. Use a soapy film and rubber squeegee(made mine from kitchen utensil) precut to fit opening and let film flatten out. Hang up and Drive |
Re: Window tint - pros and cons 3 Attachment(s) Baby shampoo and water is a nice fluid to work with window tint on. Should help get rid of bubbles and will dry out. Can’t remember the exact ratio since it’s been a while since I’ve tinted a car window but I think it was 1:3 for shampoo to water. Squeegee definitely key, rubber is best. I stick with the Tamiya smoke. Up close it’s not the cleanest but it can be passable. Few different shades below. |
Re: Window tint - pros and cons I like tint. |
Re: Window tint - pros and cons I like the idea of window tint. I see it all over the place on ebay for under $10. Here is a 20" x10' roll of 20% which is more than I would use in 10 years. https://www.ebay.com/itm/VLT-20-Uncu...gAAOSw9tJaajUk |
Re: Window tint - pros and cons I tint every body I do. Just dont look right to me with clear windows. Although I go the easy route and just use the tint spray paint |
Re: Window tint - pros and cons I bought some headlight tint that worked pretty well. I just got lazy and quit doing it ha Sent from my iPhone using Tapatalk |
Re: Window tint - pros and cons |
Re: Window tint - pros and cons thats a great idea i neveer would have thought about using actual window tint i have always used the tamiya smoke but i dont always like the result |
