Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Would the acetone in abs glue melt or stick to a lexan body?
Old 10-14-2019, 05:02 PM   #1
Default Would the acetone in abs glue melt or stick to a lexan body?
Just imagining making organic looking exocages by pouring the black plumbers abs glue over a body.
Or trying to coat the inside to make a Hardbody.
Sent from my SM-N950U using Tapatalk
Voodoobrew is offline   Reply With Quote
Old 10-14-2019, 05:30 PM   #2
Default Re: Would the acetone in abs glue melt or stick to a lexan body?
You could test this on some lexan scraps.
My guess is it will likely melt.
Is the ABS glue similar to the MEK that we use on hardbodies?
HumboldtEF is offline   Reply With Quote
Old 10-14-2019, 05:36 PM   #3
Probably the same.
Old 10-14-2019, 05:38 PM   #4
Abs glue is like acetone or mek mixed with abs bits that have fully melted into a solution. So it dries solid after the mec or acetone evaporates.
I have an old tube of mek I got from a swamp cooler install.
Mek is similar but it dosent dissolve as wide of a range of plastic and dries slower.
Old 10-14-2019, 05:41 PM   #5
Using some scrap pieces, might I suggest giving Plastic Weld a try. Test ABS to ABS, ABS to Lexan, and Lexan to Lexan. The only "downside" is that Plastic Weld is black, but should have an incredibly-strong bond.
Panther6834 is offline   Reply With Quote
Old 10-15-2019, 11:40 AM   #6
I've used 50/50 water/acetone to try and remove paint from Lexan - it didn't melt it but it did turn it so brittle that it shattered.
QuesoDelDiablo is offline   Reply With Quote
Would the acetone in abs glue melt or stick to a lexan body? - Similar Threads
lexan body cut and glue job Jono.Welsh Newbie General 2 10-02-2014 12:38 PM
Lexan Glue? losilover Paint and Body 1 05-06-2010 05:43 PM
lexan picture glue question hitman1989 Paint and Body 10 06-19-2009 01:37 PM
Weld on 45 Lexan Glue? DaveFL Paint and Body 4 05-24-2007 12:28 PM
plexieglass/lexan glue? braceysdad Chit Chat 21 05-19-2007 06:58 AM
