01-05-2020, 09:06 PM | #1 |
| Hard Body and Liquid Mask
Has anyone used liquid mask on a hard body? If so, other than putting for or five coats on, what precautions should be taken?
01-05-2020, 09:15 PM | #2 |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: Hard Body and Liquid Mask
Not sure why you'd need to put 4-5 coats on. I started using liquid masking approx 30 years ago (I've used it when airbrushing things), and I've only done 2-3 layers. ~ More peace, love, laughter & kindness would make the world a MUCH better place |
01-06-2020, 12:12 PM | #3 |
Whenever I use liquid mask on lexan I use 4 - 5 coats, makes it easier to get the mask off. I was just wondering if there are any particular "do" or "don'ts" of using liquid mask on ABS bodies.
01-06-2020, 02:09 PM | #4 |
Quarry Creeper Join Date: Jun 2015 Location: France
I've used liquid mask for my Isuzu CC01 without problem, but not direct application though, the body was painted first then masked where I didn't want clearcoat.
01-08-2020, 06:39 PM | #5 |
Quarry Creeper Join Date: Dec 2019 Location: Woodstock
Yes I do and like it a lot, was not real sure at first. Getting crisp edges, you want to try to flow it on. Does not act like paint, it wants to slip around more. For instance, start to lay down a strip say 1/8" moving along you notice a hollow area. Keep moving, allow that area to set up/dry some then go back and fill. Anyway it is a good worthwhile product, jump in and start using it, no words can help more then just doing it. As mentioned find something to use it on,. Get the feel before attempting the model Also use it with acrylics, bottle says works best with water base . I found no down side using it with acrylic paint. Myself, good new discovery this product, so many uses., have 2 parts to glue and paint, mask off the area to be glued, and paint. Plastic too plastic, stronger bond pep Last edited by JacktheRipper; 01-08-2020 at 06:43 PM. |
Hard Body and Liquid Mask - Similar Threads | ||||
Liquid mask | jeeptec | Axial SCX10 II | 4 | 01-17-2019 06:02 PM |
Removing Liquid mask from lexan body | Microgolf | Newbie General | 12 | 02-02-2017 02:09 PM |
How long can you leave liquid mask on a body? | Stregone | Paint and Body | 3 | 05-02-2014 02:25 AM |
Liquid mask: First try. | RIG_RIDER | Paint and Body | 15 | 05-12-2011 10:13 AM |
Liquid mask on outside of body | Hordsak | Paint and Body | 2 | 05-07-2010 06:20 PM |
