03-31-2020, 07:46 AM | #1 |
| Bonding aluminum to ABS?
OK RC Crawler Folks - I need to bond some 1/2" diameter aluminum tubing (1/8" or so wall thickness) to ABS sheet material. It does not need to be structural in its bond, this is merely a cosmetic, scale item application. I've done some research, and I found that Permabond makes a product called Permabond TA4246, specifically designed for this. However, at around $65 for the kit, it's a bit rich for my blood and this small application. Anyway, just wondering if anyone else has tried, had success with alternate products / similar materials. Thanks in advance for any feedback! |
03-31-2020, 08:48 AM | #2 |
| Re: Bonding aluminum to ABS?
I have had success with shoo-goo, and e6000. Not to abs specificly, but to lexan.
03-31-2020, 08:52 AM | #3 |
if the aluminum is painted any glue should work e6000 type of stuff if its not painted the aluminum oxidizes and the glue lets go
03-31-2020, 09:04 AM | #4 |
| Re: Bonding aluminum to ABS? |
03-31-2020, 09:16 AM | #5 |
I haven't tried to bond them materials together, but I have used this JB Weld to bond other materials. Maybe this will work! |
03-31-2020, 09:42 AM | #6 |
I wanna be Dave Join Date: May 2011 Location: Lost in Oregon
Tried JB weld....didn’t do so good....needs metal to metal I found an adhesive product at Home Depot that supposedly adheres any material together. I used it on concrete and wood...also holds rocks and such together nicely. Strong and waterproof. I can’t remember the name....(not enough coffee). But it’s stupid simple...I’ll find the tube and take a picture....I bet it would work Supposed to bond anything to anything.... Found it....it’s called “liquid nails “.....comes in a tube for a calking gun Last edited by Postclanker; 03-31-2020 at 09:46 AM. Reason: Found it |
03-31-2020, 10:15 AM | #7 |
Rock Crawler Join Date: Nov 2019 Location: Erie
Loctite Epoxy Instant Mix (mixes as it goes through the tube) should bond just about any 2 materials together. Costs roughly $4 for the tube.
03-31-2020, 10:46 AM | #8 |
Thanks for all the ideas and replies guys. I'm going to do some tests with the JB, Liquid nails (which I have used for construction projects) and the Loctite Epoxy. I'll report back.
03-31-2020, 10:51 AM | #9 | |
| Re: Bonding aluminum to ABS? Quote:
Whichever route you take just be sure to allow proper curing time. Many will “bond” instantly or within minutes, but might require 24 or more hours to cure. | |
03-31-2020, 10:53 AM | #10 |
04-02-2020, 04:42 PM | #11 |
Rock Stacker Join Date: Oct 2019 Location: Saugerties
Fuze-it works better then liquid nails on bonding different types of materials together Sent from my GM1917 using Tapatalk |
Bonding aluminum to ABS? - Similar Threads | ||||
bonding lexan | cutlaSS | Tools, and Procedures | 2 | 04-07-2016 04:34 AM |
Bonding Lexan | Pain4WD | Paint and Body | 5 | 06-05-2012 02:34 PM |
Bonding Aluminum? | rcbif | Chit Chat | 3 | 04-28-2009 10:48 AM |
Need Help Bonding Polycarbonate | Casper06 | Paint and Body | 3 | 03-09-2009 06:56 PM |
Bonding ABS | cheapjeep2 | Chit Chat | 3 | 08-08-2006 08:12 AM |
