Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Rustoleum 2X paint ?
Old 01-09-2021, 05:54 PM   #1
riz
Default Rustoleum 2X paint ?
can Rustoleum 2X paint be used on the inside of a clear lexan body? I know it's for plastic but not sure for lexan?
Any help appreciated.
RIZ
riz is offline   Reply With Quote
Old 01-09-2021, 06:53 PM   #2
Default Re: Rustoleum 2X paint ?
I have used regular Rustoleum, Krylon, and cheap Home Depot generic spray paint on both inside/outside of 4 lexan bodies that were not treated kindly and have not had any paint flake off or crack. I cleaned with dish soap and scuffed with a scotch brite pad, then wipe down with alcohol. Light mist coat x2 then go at it. I think just based on my experience painting almost any surface or material you can think of with almost any brand of paint that prep or lack thereof is responsible for 90% of failure, 9% is technique, and the remaining 1% is compatibility.
Phildirt is offline   Reply With Quote
Old 01-09-2021, 09:44 PM   #3
Yep. I’ve painted 4 bodies with normal paint(not because I want to, but I can’t get lexan paint to me) and they have been fine. A little bit of flaking around the edges on one, but also I never scuff the body. the flaking spots were also on the outside. So yes, it’ll work and it’ll look good.
_________________
SCX10 ii
TRX4
ScaleLifeNewbie is offline   Reply With Quote
Old 01-11-2021, 12:04 PM   #4
It'll work fine, but if its your first paint job, I would stick to paint formulated for lexan, just because it's a little kinder to beginners if you didn't prep the body right.
I've had mixed results with standard spray paint and lexan, sometimes it sticks, sometimes it chips off in the first impact.
TITANIUM94010 is offline   Reply With Quote
Old 01-11-2021, 11:05 PM   #5
dezfan's Avatar
Ive done some sample pieces of Polycarbonate w/ 2X paints.
Clean the body with HOT soapy water and then dry.
Scuff with an scouring pad being very careful around the windows.
Wash again with HOT soapy water, rinse and dry.
Wiping with alcoholic couldn’t hurt.
Warm the paint up on a sink of warm water, wipe the cab down, then shake it well for 2-3 minutes.
Apply a mist coat and let it flash (about 15 minutes), then apply a second light coat and again let it flash. Then apply another heavier coat to get full coverage.
Let it dry for several DAYS.
At this point it’s pretty tough.
I’d still back areas that may rub on the body with some Gorilla tape to prevent the paint from being rubbed off.
It isn’t perfect, but it will work. And after you drag it across the rocks for a white, you won’t care so much if it starts to chip a little.
dezfan is offline   Reply With Quote
Old 01-27-2021, 08:58 AM   #6
I've had decent luck with the Rustoleum 2X paint but it definitely applies differently than say the Tamiya spray.
Prep is key as mentioned above.
No-Idea113 is offline   Reply With Quote
Rustoleum 2X paint ? - Similar Threads
Ok to back with Rustoleum? big_poppa49 Paint and Body 8 01-26-2016 09:09 PM
Had a little fun with some Rustoleum paint and my wifes SUV yesterday Hoosierdady Chit Chat 11 05-09-2015 07:19 AM
rustoleum never wet? Beej Axial SCX-10 2 07-30-2013 09:23 PM
Rustoleum Enamel Mr.Joshua Paint and Body 11 10-18-2011 09:44 PM
Any paint geeks out there?? Rustoleum picklewagon Paint and Body 13 02-10-2010 10:08 AM
