03-25-2022, 06:29 AM | #1 |
Newbie Join Date: May 2015 Location: K-Vegas
| Newb to painting
I'm going to be painting my first body and I want to cut out the hood so I can hinge it to have access to the front mounted battery. Would I be better off to paint it and then cut it out or cut it out ahead of time and paint the pieces separately? Thanks in advance. Sent from my SM-G986U using Tapatalk |
03-25-2022, 06:38 AM | #2 |
I wanna be Dave Join Date: Sep 2019 Location: US
| Re: Newb to painting
I'd cut out the hood first...but, I might suggest having two bodies. To get everything cut as perfectly as possible, you're going to need to 'destroy' a lot of material on both sides of the "cut line". I can't tell you how to go about doing it...but, I can tell you, of I was the one doing it, I would definitely be using two bodies. And, as for "cutting" the bodies, of probably (VERY carefully) use a Dremel. Best of luck...and, looking forward to seeing the finished look. ~ More peace, love, laughter, & kindness would make the world a MUCH better place |
03-25-2022, 08:14 AM | #3 |
Quarry Creeper Join Date: Jan 2021 Location: in the Canyon
If you're using a single body to do it, I'd recommend X-acto/scalpel and go really slowly. Anything that cuts with abrasive is gonna leave a BIG gap.
03-25-2022, 08:19 AM | #4 | |
| Re: Newb to painting Quote:
Sent from my SM-G986U using Tapatalk | |
03-25-2022, 08:20 AM | #5 |
I would cut then paint. I would use the score-and-snap method with an X-Acto knife. Following the hood line on the body, gently score the lexan a few times, then gently fold the lexan on the score line and it will "snap" leaving a nice clean line. This method is sometimes easier than cutting with lexan scissors. Go slow, take your time and good luck! |
03-25-2022, 08:21 AM | #6 | |
03-25-2022, 08:24 AM | #7 | |
03-25-2022, 08:28 AM | #8 | |
Cutting wheels would leave too big of a gap. That's why I like the score and snap method. Your welcome! | |
Newb to painting - Similar Threads | ||||
newb here well sorta newb!!!! | tpurdin | Axial SCX-10 | 5 | 11-04-2012 10:18 AM |
not a newb but have a question of newb stature | Brandon88 | Electronics | 11 | 04-14-2010 08:53 PM |
Newb question to beat all newb questions | vinster888 | Newbie General | 3 | 12-29-2009 07:24 PM |
im a newb to painting | axial goats | Paint and Body | 5 | 09-16-2009 10:19 PM |
Painting Basics - Painting Tips and Tricks | stampedeproject | Paint and Body | 0 | 03-09-2008 10:39 PM |
