Go Back   RCCrawler Forums > RCCrawler General Tech > Paint and Body
Thread: Oven Cleaner won't work
Old 04-15-2007, 01:20 PM   #1
Default Oven Cleaner won't work
I'm trying to strip a clod body so i can do some modifications on it and the oven cleaner isn't working. I put the body in a garbage bag and sprayed it and sealed it for about 45 minutes, and the paint didn't even loosen up. It was some stuff my parents had its the Top Crest brand, not the easy off. When i sprayed it, it did sort of have a citrus smell, so maybe its equivilant to the easy-off in the green can?
Is it the cleaner or the paint? should I go to the store and get some actual easy-off brand?
Racefan1115 is offline   Reply With Quote
Old 04-15-2007, 01:31 PM   #2
yeah, get the easy off yellow can, and its going to take more than 45 minutes, way more. maybe a day or two, i'm reading up now myself on how to strip paint.
Thorsteenster is offline   Reply With Quote
Old 04-15-2007, 01:45 PM   #3
Yeah, i figured I would need easy off. I knew it would take more than 45 minutes, but i tried scraping it with a gasket scraper and it did nothing at all.
Old 04-15-2007, 01:46 PM   #4
Try Brake fluid
Kev808 is offline   Reply With Quote
Old 04-15-2007, 02:09 PM   #5
Brake fluid will work, just not quickly. Especially if it has a lot of coats of paint. I tried brake fluid on a Juggernaugt 2 body and it lifted the paint in about a week. But it had close to 5 different colors of paint. I also felt that it made the plastic a little brittle after removing it and letting it dry. Just my opinion. It did work, but it takes awhile.
hvydty1 is offline   Reply With Quote
Old 04-15-2007, 02:28 PM   #6
Originally Posted by Kev808 View Post
Try Brake fluid
You mean brake cleaner, and that has a tendency to eat plastic.
Old 04-15-2007, 02:31 PM   #7
If you want something fast, Then see you can get ahold of a product called Bulldog Flexible Parts Stripper made by KleanStrip Automotive/Aircraft remover(sometimes they have it at Wal-Mart in the auto dept. or at your local auto parts store) We use it alot at work (Autobody industry).
It is very strong, so I recommend using protection; gloves, goggles, respirator.
Old 04-15-2007, 03:04 PM   #8
I've tried brake fluid and an off brand overn cleaner and neither worked very well. Guess you gotta get the good stuff. I have a question on the process though. You spray and seal it in a container for days. Won't it settle at the bottom and eat away more there? Or does it produce fumes which are what does the stripping?
Jamus is offline   Reply With Quote
Old 04-15-2007, 03:11 PM   #9
Are you asking on the product I mentioned about?
Old 04-15-2007, 03:37 PM   #10
I took a trip to the store and got some easy-off and put that on there. I will let you know how it works compared to the other stuff.
Old 04-15-2007, 04:10 PM   #11
No I was asking about the oven cleaner and brake fluid. I imagine a real stripper would work fast enough that you wouldn't leave it for a long period of time.
Old 04-15-2007, 04:26 PM   #12
I just checked the progress on it, and so far the easy-off doesn't seem to be a whole lot stronger. There is two coats of paint on it, and where the top one is cracked it came off, and the first layer is gone also. But elsewhere on the body i can't even scrape the top layer with a gasket scraper. I'm wondering if its automotive paint on there or something. I'll let it sit for a few hours and see what happens.
Old 04-15-2007, 04:44 PM   #13
i used easy-off on my wrangler, the paint had been on it for about 10yrs you have to let it sit over night , and you mite have to doit several times and rince it off inbetween. use a hard toothbrush when you rince it off
brake fluid works also but you need to sock it for a few ours
i would use the easy-off ....the foamig kind
dwagon is offline   Reply With Quote
Old 04-15-2007, 05:06 PM   #14
Yeah, I've got the foaming easy-off on there right now. My body is an original clod, so I'm pretty sure that the paint on my body is really old also. I'll let it try sitting over night and see what happens. I'm hoping if it worked for you it will work for me
Old 04-15-2007, 05:11 PM   #15
06 Super National Champ
JasonInAugusta's Avatar
No, he meant brake fluid. Brake fluid works...on both lexan and styrene.
For anyone reading this...DO NOT USE BRAKE CLEANER!
JasonInAugusta is offline   Reply With Quote
Old 04-15-2007, 05:15 PM   #16
Nitro works on lexan as well. but i have used brake fluid before and it worked great, just took a while afterwards to get the residue off
'83 chevy is offline   Reply With Quote
Old 04-15-2007, 05:15 PM   #17
Oops, i'm assuming that thats why when i tested it on a piece of scrap plastic it tended to eat the plastic
Old 04-15-2007, 06:50 PM   #18
Default brass brush
I found that a small brass "toothbrush" that I used to clean my brazing worked well to clean my hummer hardbody. I was afraid that it would gouge the plastic, but it didn't (even getting all of the paint off of the door hinges and rivets). Apply as little pressure as you can and go fast at different angles. Keep checking to see if anything is damaged, I just don't want to get blamed for ruining it. I used the off brand of oven cleaner and let it set overnight each time.
NeoNeoN is offline   Reply With Quote
Old 04-16-2007, 12:33 AM   #19
It'll start working as soon as it touches the painted surface. and eats it up real quick. Whenever I use it at work, It can strip paint off a full size truck hood in 15-30 min.
Old 04-16-2007, 03:30 AM   #20
I use the yellow bottle of eazy off and a tooth brush. I put the body in the bag after I spray it. I let mine sit out in the sun since eazy off is heat activated. The sun will help eat more of the paint. Don't forget to wear rubber gloves. I found that out the hard way. My hands hurt for days after.
minijosh is offline   Reply With Quote
