02-12-2008, 12:48 PM | #1 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
| rebuild kit?
where can i get a rebuild kit for the grc12 shocks (blue threaded one's)?
02-12-2008, 04:49 PM | #2 |
Rock Crawler Join Date: Apr 2005 Location: Upland
What do you need to replace? The O-rings are just standard shock O-rings. Any 0-ring for a Traxxas or similar shock should work. If you need the entire shock seal (ie, spacers and o-rings). Contact PTI.
02-13-2008, 10:47 AM | #3 |
I wanna be Dave Join Date: Dec 2005 Location: Tax Nation
best rebuild kit I have found is a nice set of Traxxas big bores.... I have given up on making the shock pti shocks anything but marginal (I know people will disagree)
02-13-2008, 05:07 PM | #4 |
cool i just did a rebuild on some big bore shocks and the blue x-rings on some of them were still good. so ill replace the bottom o-rings with the x-rings and see if the shocks stop leaking. |
02-13-2008, 05:18 PM | #5 |
It's a good idea to use Associated's green slime when rebuilding shocks (or building shocks in general). It will prevent the shocks from leaking and lube the o-rings so they won't tear when you insert the shock shaft (put a little on the threads too).
02-14-2008, 03:07 AM | #6 |
Quarry Creeper Join Date: Apr 2007 Location: Kapahulu Safeway
The shocks are made by GPM. You could contact them.
