09-15-2008, 04:11 PM | #41 | |
Rock Crawler Join Date: Apr 2005 Location: Upland
Thanks! I'll get a set and see what I can do and how feasible it is to do multiple parts for people. I'll post my progress in a new thread once I get the parts. Quote:
09-15-2008, 08:31 PM | #42 | |
Pebble Pounder Join Date: Jul 2008 Location: Trumbull, CT
thats where the problem lies , the spool for any manufactured bevel gear to work would need to be made backwards with the indentation on the back side(the holowed out part) . if you try to use it using it the same way as the plastic bevel gear goes on it does'nt line up at all in the axle housing (and the bevel part is on the wrong side). if anything it may be easier to make a new spool for the losi gears to make a direct fit ,or new smaller cups so you could use the driveshaft from the losi bevel gear. a new spool will be the easiest setup | |
09-17-2008, 03:33 PM | #43 |
Quarry Creeper Join Date: Mar 2008 Location: Hilo
Either way works for me. Ill be interested to see what OGmicromonster comes up with.
09-26-2008, 11:51 AM | #44 | |
09-26-2008, 11:38 PM | #45 |
10-02-2008, 10:49 AM | #46 |
10-06-2008, 11:57 AM | #47 |
Any updates?
10-06-2008, 12:04 PM | #48 |
10-06-2008, 06:53 PM | #49 |
these are one tough gears. before cutting the gears would it be easier to make a new spool to fit these gears or do you still need to cut them ?
10-07-2008, 10:26 AM | #50 |
| Well my father-in-law and I both looked at them and decided it would be easier to cut the gears and use the existing spool. To make a new spool would require a bit more work. Plus to get the unmodified Losi gears to fit would require grinding a lot of the PTI axle case. The Losi ring gear is the exact same diameter as the PTI/Associated one. The difference is the extra material that the Losi gear has on the backside. Once that is removed, the Losi gear will be the exact same thickness as the stock PTI/Associated gear. The hard part actually is getting the pinion to fit in the stock location. The diameter of the pinion is larger than the stock PTI/Associated pinion. So we'll need to figure out how to get it to fit. The idea is to try to get the gears to fit with as little modification to the stock PTI parts. This way we can modify the gears for you guys and you just install them. We'll see how it works out though. I know there will most likely be some grinding to the stock PTI axle cases to get the gears to fit properly. But we'll try to keep it to a minimum.
10-07-2008, 02:13 PM | #51 |
Im getting excited |
10-07-2008, 06:52 PM | #52 |
sweet |
10-15-2008, 02:31 PM | #53 |
Any progress?
10-15-2008, 09:32 PM | #54 |
Everybody here should bug RC4WD to do it, I have, I think they are our only chance at getting this done.
10-16-2008, 09:25 PM | #55 |
Newbie Join Date: Sep 2008 Location: PUERTORICO
| skid plate for grc
Need some help or direction on where to get a strong front skid plate for my grc; start messing with it and broke any sugestion beside PTI site. Would like to get a stronger one,Thank for the help |
10-16-2008, 10:46 PM | #56 |
RCC Addict Join Date: May 2007 Location: pasadena, tx
10-17-2008, 02:05 AM | #57 | ||
So any new news on the modified Losi parts? | ||
10-17-2008, 06:43 PM | #58 |
10-17-2008, 07:19 PM | #59 |
| Skid Plate |
10-17-2008, 09:10 PM | #60 |
