09-20-2008, 07:30 AM | #21 |
Rock Crawler Join Date: Oct 2005 Location: Clarkston, MI
09-20-2008, 08:41 AM | #22 | |
they arent trying to spin a 5'' tire from a dead stop with maximum torque. thats like saying a crawler can use 64p spurs because oval racers do and dont strip them easily. but i know what your saying, the plastic ( actually composite material ) can hold up to a certain amount of abuse. | |
09-20-2008, 09:03 AM | #23 |
Rock Crawler Join Date: Jan 2006 Location: Bellaire, MI
09-21-2008, 10:55 AM | #24 |
Working for an aftermarket manufaturer I have owned and/or beaten about every truck even semi popular to crawling. In one day we completly ruined 2 PTI's. It was during a session when two of us were actually working with PTI to try and figure what to do to improve the truck. I was uneasy about getting on board with the project. PTI sent two kits with GRU and the stretch kit. We ended up destroying both trucks in one day. Absoultely no way I would ever purchase one. They are not up to the hardcore abuse. |
09-22-2008, 02:03 PM | #25 |
Well, in my belief (not personal use) I think the truck itself is bad. The axles on it are okay, but only the newer revision cases. The older ones were sloppy, and if you sand them down even further (just a little) to reduce slop and flash, then they are even tighter. The ring and pinion can be good. The Poulson axles use the same gears and input shafts, and they can make it to the top 5 at Nats (Naz-T and the Agent J 2007) so I trust the drivetrain, but it's not up to something like a cobalt puller. More suited to a lightweight rig, with less power. Oh and by the way, Axial axles are better. PTI axles are okay but unless you already have them, don't use them.
09-23-2008, 09:50 AM | #26 | ||
Rock Stacker Join Date: Oct 2005 Location: Stationed in MO, born in TX.
Beat me to it Robbob! | ||
09-25-2008, 02:07 PM | #27 | |
RCC Addict Join Date: Jan 2008 Location: Wetlands
I kicked MYself six months ago for buying the PTI last year. Would you put a Honda civic diff. inside a DANA 60? Well thats what is in the PTI axles, A little race car diff. Optional parts are minimal to nothing. Its a great challenge to try and make it work though. Let us know how turns out if you decide too continue with the PTI. Last edited by Da Hermit; 09-25-2008 at 05:49 PM. | |
09-30-2008, 07:06 PM | #28 |
Quarry Creeper Join Date: Mar 2007 Location: hartland wi
so, is there anyway to make a goliath competitive?
09-30-2008, 08:37 PM | #29 |
Rock Crawler Join Date: Nov 2004 Location: Roseville
10-11-2008, 12:38 AM | #30 |
Newbie Join Date: Aug 2007 Location: Lake Stevens
My sons pti is a better crawler than my tlt sw2 at the moment..I may be fairly new to this but he is 10 and his truck is still holding on after about a year..we had a few minor probs to start with but after the stretch its a fine truck.Just my 2c
10-12-2008, 01:19 PM | #31 |
Rock Stacker Join Date: Mar 2006 Location: montrose co
i'm gonna swap a ax10 tranny into my goliath, to lower the cog. see how this does, i might even use the ax10 chassis, and cut links to fit. right now, i am comfy with the axles, using a 55t and 6 cells.
12-03-2008, 09:33 AM | #32 |
Newbie Join Date: Feb 2007 Location: Germany
What makes it so special: Upper links delivered in Extension-Kit are WAY TO SHORT, about 1/3" to short. USELESS! COMPLETE USELESS! To have a good angle for the axle you're on the end of the thread. No pinky, no brain. Axle Braces reduce Steering TOO MUCH. Nice idea. Nobody needs steering. Having no Servo saves energy. Axle-Brace-Screws are TOO SHORT. It's more like a "Now you can see we really wanted to send you screws, but sorry...*smile*" Chassis-Rails are bended a little and have sharp edges like X-Acto dreams of. Saves buying a knife to open the bags. Good idea! The Screws are cheap, you can't build it crawl-ready using them, only tighten them softly, and YES, i have correct tools. All sizes Wiha professional screwdrivers. It's a brandnew alloy using steel and creamed corn (Patent pending). CVD's stuck if angle is too much between axle and driveline. Stock angle is TOO MUCH. Funny! Haha. Choose between buying a PTI or smashing with a hammer on sum aluminium/plastic til it looks (use ur fantasy) like a crawler part. From this point it's the same work you have to do on both to make it a working crawler. XbX (has 2 PTI GRC but no fun) |
12-03-2008, 09:34 AM | #33 |
12-03-2008, 04:35 PM | #34 |
RCC Addict Join Date: Jan 2006 Location: Irritable Isle
With the coming metal gears and dig tranny that PTI has informed me are coming my way soon, I look forward to updating my PTI. It hung well with the other TLTs and Axials before the coming of bigger power and dig. I think it will be competitive once these two pieces are installed.
12-04-2008, 01:55 AM | #35 |
Quarry Creeper Join Date: Jul 2005 Location: pleasant ridge
a pti is like a tlt it takes time and money to be comp worthy.with a axial they took the downfall/short comings of the more generalized ogs and sent you a 90% comp rig in a box.i got my pti when the only other choice was a tlt. this was by far more comp worthy than a tlt stock.
12-04-2008, 03:08 PM | #36 | |
Pebble Pounder Join Date: Dec 2004 Location: NYC
12-04-2008, 03:38 PM | #37 |
12-31-2008, 10:21 AM | #38 |
Newbie Join Date: Aug 2005 Location: Colorado Springs
I bought a PTI when they first released the goliath. At the time, the TLT was really the only other thing out there. I spent some time tinkering with it and managed to burn a 55 turn lathe motor because the gearing sucked. I enjoyed building the thing but agree the screws were mostly too short. I eventually purchased a gd600 GRU and some traxxas links to lengthen the rig. I got around to lengthening it with my set up and found ways to mount the shocks. But while I was trying to figure out a way to build driveshafts, PTI released the lengthening kit. I purchased it, but never installed. So now my PTI sits in a box, half build / half in pieces while I plan to buy an Axial. As for the axle quality, I only stripped one gear, but that was my fault. I did not tighten a screw in the diff well enough and it fell out while I was driving and took out the gears. Never had a problem with any of the other parts, but I have only ever bashed with it, never real crawling or comps. Why am I going Axial? Because I like the looks of it and I really like the HBZ warthog and want that. |
12-31-2008, 08:41 PM | #39 |
Rock Crawler Join Date: Aug 2007 Location: Orlando
i use axials all the way but mine are all aluminum..work great no problems, ill strip a hex before stripping a gear inside these things. iv never used pti axles nor never will but all i can say is that axial is a great crawler all around and the axials can handle the tourqe(my opinion)
04-11-2009, 07:18 PM | #40 |
Newbie Join Date: Aug 2008 Location: dexter
looks liek there is alot of dispute over AXIAL'S and PTI'S
