12-21-2008, 04:02 PM | #1 |
Rock Stacker Join Date: Nov 2008 Location: Santee
| GRU or high turn motor?
I want to get more climbing crawling ability from my PTI....is it better to go with a GRU like the RC4WD sells or go with a 80-100t motor?
12-21-2008, 04:41 PM | #2 |
RCC Addict Join Date: Jan 2006 Location: Irritable Isle
Adding a GRU is best. You want have reduction and be able to have a bit of wheelspeed as well. A 80t motor would most likely be too slow. I have used a GD600 with good results and currently have the PTI GRU installed. Both are good. The RC4WD GRU would also be a good choice.
12-21-2008, 06:45 PM | #3 |
I would like to find a PTI gru, but they havent released the new one yet, and I cant find any of the old ones. Anyone running the RC4WD one have pics or reports? |
12-22-2008, 11:21 AM | #4 |
Rock Crawler Join Date: Sep 2008 Location: N.E. Mpls
*I have rcfwd 4:1 unit. I had some issures figureing out what pinion to use. On the 4:1 unit it ended up being a 14t 48 pitch. I could be wrong but that is what is in there now. I have been running a 45t integy into the 4:1 then into the disruptor xfer case and I think my wheel speed is to hi. This is a scaler with very little intent on being a good crawler, but will look good... My esc fxr seems to everheat in short time. I am guessing i need more reduction or a higher turn motor... I have been thi9nking about a 65t... Oh btw I am running this set up in a 1/6 scale running 2.2. I am also running 3s Hope this info helps ???... |
12-22-2008, 03:15 PM | #5 |
Newbie Join Date: Sep 2008 Location: PUERTORICO
if possible can you explain how to instal that GD 600 i would like to install one on my Golliat and can you tell me wher to get it. Actually i'm using a Rooster Crawler ESC with 55T; any recomendations. Thanks for your help
12-22-2008, 10:28 PM | #6 |
I am planning on getting the RC4WD gru in the next week or so. I am running a 55t motor, and will try the 12 or 10 tooth 48 pitch pinion gears I have. I am also looking into a different speed control as the Futaba I have now has no brake and a very anoying reverse delay. |
12-24-2008, 07:25 AM | #7 |
Rock Crawler Join Date: Nov 2008 Location: lakeside
get the caslte sidewinder, or the tekin FXR, these to seem to have the most a[FONT='Calibri','sans-serif']djustably. [/FONT]the novak rooster crawler is good and it more of a plug and play, very good brake.
