Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > PTI Goliath
Thread: ? ABOUT pti
Old 06-19-2006, 10:26 PM   #1
Default ? ABOUT pti
HEY YALL dose anybody make a metal pinnion gear for the axle of pti goliath?
Skyjacker56 is offline   Reply With Quote
Old 06-19-2006, 10:48 PM   #2
I don't think so - they use TC3 gears.
Mad Scientist is offline   Reply With Quote
Old 06-19-2006, 10:51 PM   #3
Default thanks
I wasin't even sure what gears they used. Thanks
Old 06-20-2006, 05:43 AM   #4
Hell's Gnome
LumTheMad's Avatar
PTI general info: http://www.one18th.com/forums/forumdisplay.php?f=151
Still no metal gears.
LumTheMad is offline   Reply With Quote
Old 06-20-2006, 06:26 AM   #5
WRXronald's Avatar
Default speaking of...
it's become my opinion that it really sucks they are no available internal metal gears for the PTI axles. I'm shortly going to drop some TLT axles in place of my PTI's... i keep stripping the ring and pinion gear inside the gear case.
WRXronald is offline   Reply With Quote
Old 06-20-2006, 12:00 PM   #6
That seems to be a deal-breaker for most people. Too bad, too - I kind like the PTI.
Old 06-20-2006, 02:06 PM   #7
K_B
I was told by the guys at PTI that the gears are now made from Delrin. So I guess there are TC3 gears out there made of delrin, since PTI does not produce the gears themselves.
But if you ask me, the material isn't what makes the gears slip. I'm thinking that the tolerances in the axle housing along with some flex in the housing are what's causing the slippage. The only difference that identically designed metal gears would have is that they'd be louder when they slipped....
K_B is offline   Reply With Quote
Old 06-20-2006, 03:05 PM   #8
felsenfest
EGRESSor's Avatar
Ron, i want your axles
EGRESSor is online now   Reply With Quote
