04-06-2012, 07:21 AM | #1 |
Newbie Join Date: Oct 2011 Location: clarksville
| bigboy setup
I recently bought a goliath on ebay but it hasnt come yet. it is heavily modified and streched, with a tamiya teu101bk esc and an integy 65t motor and some kind of gear reduction. What I'm looking to do is use a Mamba Monster esc i have already, question is what motor should i run with that much esc, i have plenty of 2s and 3s batteries to use and being that i can switch to a brushed or brushless motor, plus have full control of my BEC, it should make for a good setup. Also Was wondering what i can do to make my pti a 4ws, looks as simple as mounting a rear servo, getting some linkage, and putting a "Y" connector in my receiver at the steering port. ANY HELP IS APPRECIATED!!
04-10-2012, 05:19 PM | #2 |
| Re: bigboy setup
Unless you replace the entire transmission with something like an axial tranny, you can't run very powerful motors; the tranny (or lack thereof) will just blow up. And the gears in the axles can't take much power either unless you can get your hands on a set of the metal ring/pinions. Were you planning on using it as a crawler or a general basher? As for 4WS, that's pretty much like you said: fab up a servo mount, get some linkages and REVERSING Y-harness and you're set. |
04-10-2012, 07:25 PM | #3 |
| Re: bigboy setup
no as a crawler... it came today, may just steal the axles from it, and buy a losi comp crawler chassis and links, cause this thing looks like junk... thanks for the help
