Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > PTI Goliath
Thread: PTI Goliath
Old 01-08-2007, 03:48 PM   #1
Default PTI Goliath
Has anybody got one of these,I have looked around and haven't found any mention of them here.I noticed they make 2 models and I was looking at their rock crawler version,looks impressive but I wanted feedback from here before buying one.
red jim is offline   Reply With Quote
Old 01-08-2007, 03:52 PM   #2
Release your anger..
ThinkTank's Avatar
here's what a little bit of what i found:
pti goliath??
How is the PTI GOLIATH??
little 2.2 beast
Quick Question on the PTI Goliath
for the pti goliath owners
PTI Goliath Crawler at I-Hobby
PTI Goliath
PTI Goliath Tuber Finished
PTI Goliath Rock crawler
ThinkTank is offline   Reply With Quote
Old 01-08-2007, 04:09 PM   #3
hunter306's Avatar
From my understanding, the front and rear differentials are the weakest link on these... Apparently the can be replaced with TC diffs relatively easily, but that is more of a band-aide fix.
I was actually SERIOUSLY considering one of these as my first crawler but after reading the disappointing performance reviews on the diffs, it sounded like I was better off building a 2.2" Comp from the TLT-1 Base...
Now I agree the PTI Goliath Cralwer looks pretty nice out of the box, and has an unbeatable entry price... but for anything more than tooling around, it appears that it is not going to impress.
hunter306 is offline   Reply With Quote
Old 01-08-2007, 04:13 PM   #4
Shut up Dave
jetboat's Avatar
I have one, trashed the rear diff gear in about 30 sec's (no exageration) the e-clip had come off, replaced the gears and beat the crap out of it. Biggest problem I have with it now is it flexs so much that the cantilevers get bottomed out and get stuck. I recommend it! the diff gears are tc3 pieces just fyi
jetboat is offline   Reply With Quote
Old 01-08-2007, 04:21 PM   #5
K_B
In order to get good mileage from the diffs, they need to be shimmed. I had to do the same with my TLT too.
K_B is offline   Reply With Quote
Old 01-08-2007, 04:47 PM   #6
hunter306's Avatar
As you can tell, I am relatively new at this... Where are the shims placed to get the diffs working better?
Old 01-09-2007, 02:45 AM   #7
K_B
shims are used to push the ring gear closer to the pinion gear (which is the smaller of the two). So I would put the bearings on the diff and then slide a couple shims on the side opposite of the teeth on the ring gear. It may take more or less shims depending on how much side-to-side play there is.
Old 01-09-2007, 12:50 PM   #8
I have one (the origional kit) but I havn't really run it. I am still finishing up it's 4 wheel steering... or trying to...
Mine is a little modified, so it has taken awhile to get it this far... I made some aluminum parts..Hopefuly I will be done with it soon.
It comes with a plastic pinion gear which I managed to destroy pretty quick.
Like the guy in the last post said, I think alot of the guts are AE parts..
If you go to 1/18th.com there is TONS on info on it. Lots of guys over there ran the truck, or made it a crawler. I got some parts from guys there.
JustinC is offline   Reply With Quote
Old 01-09-2007, 05:38 PM   #9
Looking for scale goodies
Racer4Life's Avatar
One for sale here!
http://www.rctech.net/forum/showthread.php?t=143859
Tom
Racer4Life is offline   Reply With Quote
