| | #1 |
| Rock Stacker Join Date: Oct 2004 Location: Marina Del Rey
| this is using mini lst shocks the wheelbase is 10.5 inches it is using a rc4wd reduction 55t lathe motor Last edited by firestorm450; 04-03-2007 at 07:44 PM. |
| Sponsored Links | |
| | #2 |
| RCC Addict Join Date: Dec 2004 Location: Central NY
| Looks nice. Looks like your chassis is flexing in the second pic. |
| | #3 |
| yeah, the chassis has not been finished yet, i need to get a battery holder, mount the servo and electronics and put in cross braces. im planning on making top rails about a square rod quarter inch thick and bend them up to mount the shocks, it should look more scale that way. Last edited by firestorm450; 01-13-2007 at 09:50 AM. |
| | #4 |
| I crawled that crack ![]() Join Date: Aug 2006 Location: under a rock and a hard place
| PTI makes for great scale axles much more so tyhan TLT IMO, if you turn them upside down and sand a little it gets even better Keep it up and have fun |
| | #5 | |
| RCC Addict Join Date: Aug 2006 Location: trying to find out what a TVuPer is.....
Build looks really good; brace up those rails and take the price tag off the one (first pic) | |
| | #6 |
| the axles are about the same width. i think i'll have to get some goop off to get the sticker off completely. the rear axle is the same as the front, but i have locked it out. pti designed the axles with a really good way to lock out the knuckles. im not sure what to use for braces, i was thinking of ordering sections of metal from onlinemetals.com, but i dont have a drill press, nor a good vice, so im stumped. i would like the brace to be tapped, rather than use a long bolt and nut. im thinking of changing the rails for a .25 inch square rod, and bending it. mounting things will be easier that way. with the shocks, one of the spring sets has a spring about 1/4 inch shorter than the rest, WTF. but i already opened the package, so i dont know whether i can take them back. |
| | #7 |
| Newbie Join Date: Jan 2007 Location: GRIŅON (Spain)
| COOL!!!!!!! But the socks isn´t shortly???? |
| | #8 |
| jmidym, i dont understand a word of what you just said. |
| | #9 |
| Pebble Pounder Join Date: Jan 2007 Location: Livonia
| While the PTI goliath axles do indeed look a bit nicer than the TLT-1 axles, I can tell you that the diffs are not NEARLY as smooth. Even with multiple re-assemblies of them and shimming I have not been sucessful in getting a really nice free rolling feeling from my PTI diffs. They work, don't get me wrong... it just isn't the quality that I expected for my money. This build looks very nice though, good work on the chassis. |
| | #10 | |
| | #11 |
| Newbie Join Date: Aug 2005 Location: usa
| good job |
| | #12 |
| thank you. i dont like the rails, the battery is just wider than them, so it rests quite high. hmmm |
| | #13 |
| Newbie Join Date: Dec 2005 Location: seattle
| I have the new crawler and my diff's were tight also I put a drill motor on it and heated them while turning at a high rate of speed and my diff's are smooth as silk I am very happy with the quality for the money and they are much wider than stock TLT.We just did a comparisson at the last comp and TLT with wideners and offset roms are the same width as my axles |
| | #14 |
| i found a place that can cnc for me. so i have 2 chassis ideas. which do you guys like the looks of more? top or bottom? also, how do i mount the battery cleanly on the chassis. i saw on the orcrc courier he had a cool battery holder, it was like a little tub half as long as the battery. here it is (its on the front of the chassis.) http://www.orcrc.com/outings/PDRM3742.jpg where can i get one or two? here are my designs |
| | #15 |
| I wanna be Dave Join Date: May 2005 Location: Anchorage, Alaska
| I'd say go with the bottom design. A smooth bottom will snag less. As for batteries, it would be pretty easy to make a cradle I'd think. Or go with a 1500mah lipo. They're tiny. |
| | #16 |
| the links lead to that dropped section, it will not snag. the lower links are mounted to the bottom left and bottom right holes. |
| | #17 |
| | #18 |
| Rock Crawler Join Date: May 2006 Location: san diego
| i like the top chassis design. looks like you can get the weight of the motor lower on that one. |
| | #19 |
| | #20 |
| Thread Tools | |
| Display Modes | |
