Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > PTI Goliath
Thread: PTI Goliath mmt....
Old 01-18-2007, 01:31 PM   #1
Default PTI Goliath mmt....
I just scored a great deal on a almost new one for 100 bux. I'm gonna ext it eventually and have already done a steering mod to it. Does anyone have a manual online or link they could send me to the manual and parts list? I didn't get any paperwork with it so I'm clueless. Any suggestions to get the most from this truck would be greatly appreciated?
Shaun
shaunsmaxx is offline   Reply With Quote
Old 01-18-2007, 01:41 PM   #2
Powered by Awesome
TwistedXT's Avatar
the best way to get the most out of that truck is ebay..... just kidding.
I would just stick to the normal stuff, different tires, custom 4 link and chassis, keep it low and flexible, one thing to keep in mind is that it is smaller then normal, so dont get to crazy on the tires, masher 2000's would be pushing it. the pti rock kit has imex red rocks and it makes it top heavy. also beef up the links - and most of all, post pics and have fun!!!
Welcome to the board.
TwistedXT is online now   Reply With Quote
Old 01-18-2007, 01:44 PM   #3
Here's a couple pics of it before I started tinkering.
I'm gonna flip the chassis so the batt is in front.
Shaun
Old 01-18-2007, 03:09 PM   #4
Shaun
why not just drive it backwards?
nice looking rig- wish there was more out for the PTI.
mrpink is offline   Reply With Quote
Old 01-18-2007, 03:23 PM   #5
Funny you say that as that is exactly what I'm gonna do. Well sort of. I'm just gonna move my steering to the other end and I'm set. I'm not sure what the motor is in it now but I'm just gonna switch the wires as it has fixed timing so it should be fine til I get a lathe motor for it. I might go bl in my force crawler in which case I already have the motor.
Is killerhobbies the only place that carries parts for these trucks? I went to pti's site and didn't really find much info there.
Shaun
Old 01-18-2007, 03:35 PM   #6
K_B
Killer Hobbies is about the only place I've found, but they seem pretty good to deal with so far.
K_B is offline   Reply With Quote
Old 01-18-2007, 03:38 PM   #7
K B do you by chance know if I can find a manual anywhere online for this truck? You are on one18th under same sn right? I was gonna ask you this over there but I don't think I did.
Old 01-18-2007, 03:48 PM   #8
K_B
Yeah... I'll have to see if I can find the manual and then I can scan it easy enough...
Old 01-18-2007, 03:55 PM   #9
Thank you so vary much. The guy I got it from said it didn't have 1 when he got it just the addendum sheets. He built it guessing where things should go. He did good but I wanna tear it down and redo it to be sure. I'm gonna shim the diffs then as well. I'll get lockers down the road but not right away.
Thanks again, Shaun
Old 01-18-2007, 04:46 PM   #10
thats a nice looking goliath, heck if i found a deal like that, i wouldve snatched one up!
MafiaxB is offline   Reply With Quote
Old 01-18-2007, 05:23 PM   #11
Yeah it was too good of a deal for me to pass up.
I love the look of the axles as they look alot like my force axles. Maybe somebody will start to offer up aftermarket stuff for it and they'll take off.
K B I sent you a pm.
Shaun
Old 01-21-2007, 10:13 AM   #12
Shut up Dave
jetboat's Avatar
change out that servo mount for the one they use on the crawler version and get some good tires, you could prolly buy the stuff straight from them to turn it into an awesome crawler And dont listen to the bashers!!!!
jetboat is offline   Reply With Quote
Old 01-22-2007, 01:35 AM   #13
heres a chassis kit for it http://einerbee.cafe24.com/tt/index.php buy it here http://www.toughracing.com/ 269 bucks tho if anyone else finds any parts post them
andrewmp6 is offline   Reply With Quote
Old 01-23-2007, 05:28 AM   #14
hey do you have any pics on the wheel hex's ??
hodgy_789 is offline   Reply With Quote
Old 01-23-2007, 09:29 AM   #15
Shut up Dave
jetboat's Avatar
the goilath doesnt use hex's instead it uses the setup like Duratrax uses with the pin
Old 01-23-2007, 02:41 PM   #16
I did change the servo mounting by putting it where the steer lockouts go. 1 rod to each turnbuckle and then another to the servo. This puts the servo above the axle using the stock mount and gets rid of the stock bad steering. At least it was bad on this one.
I haven't started the hunt for new rims and tires yet as those will be the last thing I prob do. The body also as it will be longer and the stocker won't look right.
I might buy longer links but chances are I'll make my own. I found some square tubing at my lhs and it looks cool after the links are done. Here's how it looks on my force crawler.
Shaun
Old 01-24-2007, 12:07 AM   #17
Here's a couple new pics. I changed the steering around. Switched the front to the back. Gonna test it then tidy up the wiring and what not plus I need to redrill body mount holes.
Gotta raise a little cash so I can place my tower order so I can get it ext. and then I might be happy. I think I'm gonna try my hand at brazing and build a tuber for it.
And 1 with my other 2 crawlers. All gettin in a little flex! lol
So if mashers are pushing it for its size does anyone have any recommendations for wheels and tires for it? The stockers will be too small once I ext it.
Shaun
Old 01-24-2007, 01:05 AM   #18
K_B
2.2 Masher 2Ks will work fine on that. Any 2.2 tire will...
Old 01-24-2007, 08:06 AM   #19
Shut up Dave
jetboat's Avatar
Im sold on redrocks on my pti crawler just have to run bb's because it has such a high cg
Old 01-24-2007, 05:20 PM   #20
K_B
This just reminded me of something. The axles will accept any type of 12mm hex for 1/10 scale vehicles. Traxxas, Tamiya, Trinity, etc. The axles are a direct swap with the TLT axles, so if you want to cheaply widen the track, you can use the Blackfoot (TG-10?) axles that alot of the TLT guys use, which seems to give the truck an ideal width for competitions.
