| | #1 |
| Rock Stacker ![]() Join Date: Nov 2006 Location: Hanson
| Hi, I have a Pti goliath crawler and was wondering if anybody makes adapters to make the truck wider. |
| Sponsored Links | |
| | #2 |
| Shut up Dave ![]() Join Date: Dec 2005 Location: Romeotucky
| since it doesnt use a hex wheel Im not sure you will find any. I have looked and so far havent |
| | #3 |
| Rock Crawler Join Date: Apr 2005 Location: Upland
| Some of HPI's wheels have a hex adapter and they make the truck about 5-10mm wider. You can try those. Also you can use Associated hexes to put wheels that use a hex adapter to mount. But for the most part you can use almost any hex adapter, you just might need to bore out the adapter slightly to get them to fit. |
| | #4 |
| I wanna be Dave Join Date: May 2005 Location: Anchorage, Alaska
| There is essentially no difference between the TLT and PTI stub shafts other than the PTI axles are a little longer; the shafts are interchangeable between the two rigs. So any widener made for the TLT will fit the Goliath. You can use Tobee Craft, G-Made or even the Blackfoot stub axles. I personally use the G-Made widerners: http://www.thecrawlerstore.com/tires...s.html#adapter (scroll down a bit) |
| | #5 |
| http://www2.towerhobbies.com/cgi-bin...?&I=LXMUF8&P=Z I have to change what I said, these fit perfect and allow you to run wideners, better wheels etc. |
| | #6 |
| I wanna be Dave Join Date: Apr 2005 Location: Kennewick
| Thats not 12mm hex You'd need these wheels http://www2.towerhobbies.com/cgi-bin...?&I=LXMUF7&P=M and then you'd need to get 16mm hexagon rod to make custom wideners |
| Thread Tools | |
| Display Modes | |
