Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > PTI Goliath
Thread: goliath transmission
Old 03-16-2007, 11:00 PM   #1
Default goliath transmission
what kinda of transmisons have people run please send pics to.
crawler02 is offline   Reply With Quote
Old 03-17-2007, 09:08 PM   #2
Shut up Dave
jetboat's Avatar
Im running the stock tranny but, need to add gear reduction, with as small as the chassis is Im not sure anything else will fit.
jetboat is offline   Reply With Quote
Old 03-19-2007, 12:49 PM   #3
I use a pede trans. I have not tried it yet. I'm waiting on parts. It is only rear wheel drive as of now. But so far I'm impressed. I was driving it around the house and I could not stop the tires. If any ting it would just wrap the tire around the wheel. The best part is, it still has good wheel speed.
speedsport22 is offline   Reply With Quote
Old 03-19-2007, 08:43 PM   #4
Nlee111's Avatar
Default ???
Is it even a transmission? It's more of a spool in mine. spur bolted right to the outdrives. I'm running a Novak crawler with stock spur, 13t pinion, and no gear red., runs great.
Nlee111 is offline   Reply With Quote
Old 03-20-2007, 07:11 PM   #5
crawling corn
jdawg53's Avatar
I am installing a associated stealth in mine.
jdawg53 is offline   Reply With Quote
