Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > PTI Goliath
Thread: PTI motor plate reinforcement GD600
Old 05-11-2007, 10:52 PM   #1
Default PTI motor plate reinforcement GD600
I would like to see how you guys are setting up your GD600 gear boxes with the motor plate. I saw one guy do something with the battery posts but I could not find it agian. And yes I did a search.
franeich is offline   Reply With Quote
Old 05-12-2007, 07:57 AM   #2
Shut up Dave
jetboat's Avatar
I bolted mine right up to the stock motor plate then used a zip tie under the back of the motor to keep it from sagging. Ill post a pic when I get home from wheeling
jetboat is online now   Reply With Quote
Old 05-13-2007, 09:29 PM   #3
I made this little brace.
Skeeno is offline   Reply With Quote
Old 05-13-2007, 11:49 PM   #4
Also the bolts that attach the gearbox to the plate keep working loose, Are you guys using locktite or lock washers
Old 05-15-2007, 12:34 AM   #5
I'm trying to determine which plate you are refereing to. Is it the side plates or the the motor mount plate?
Try longer screws. I think I have replaced most of my stock screws with 3mm hex heads. Many did strip out.
If you are refereing to the GD600 bolts, I've not had any issues there.
