Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > PTI Goliath
Thread: Goliath falls over too easily, need advice
Old 06-09-2007, 10:28 AM   #1
Default Goliath falls over too easily, need advice
So... Finally got the car built.
I installed the Red Rocks on Axial beadlocks, left the foams out and put about ~250 grams leadballs to each front tire. I also installed "hump pack" (6V, 1050mAh) over the servo to give some extra weight. The battery I'm using is LRP's 1800mAh LiPo that's installed in the front end of the chassis on top of it. The motor mount is installed the way motor is in front.
So... How is it possible the car can't even do 90 degrees without falling over (of course it won't get over the obstacle)? Should I put some weight to the rear tires too or get rid of all the weights? Any other advice to get the gc lower?
Some images of the car can be seen here... http://tomik.luola.net/index.php?dir...oliath_Crawler
Thanks,
Tomi
tomik is offline   Reply With Quote
Old 06-09-2007, 11:12 AM   #2
Question
Ok there a couple of issues with this. First the added weight is a good adie as is the hump pack. The problen is the wb. and the cog. The wb being 10 inches and the high cog, even though you've added weight up front is your problem.
DRCMAN is offline   Reply With Quote
Old 06-09-2007, 11:18 AM   #3
I found it does much better with smaller tires. I am using moabs.
franeich is offline   Reply With Quote
Old 06-09-2007, 12:01 PM   #4
Thanks...
I'm planning on making the car 12". Moabs would be better I suppose. How about Masher 2000s ? I've seen them a lot in 2.2 class -cars.
Are the sidewalls softer in Moabs than in the Red Rocks ? It seems the sidewalls aren't falling in even I have more weight on axles.
Old 06-09-2007, 05:37 PM   #5
I think the red rocks are softer. Are you using the foam? the redrocks were too soft without the foam so I did a star cut foam. I am running a star cut foam in my moabs but I am thinking of taking the foam out and maybe trying the airsoft bbs inside to give a little weight. The truck seems light to me but this is my first crawler so I dont know if more weight would be benificial.
Old 06-09-2007, 09:19 PM   #6
Originally Posted by tomik View Post
Thanks...
I run mashed 2k's on axial bealocks star cut foams and 3-4oz in each front tire. Good all around tire
Old 06-10-2007, 02:32 AM   #7
Hmm... Star cut foams. Could you post a pic of a star cut foam? I've already tried with a foam cut in half (as the PTI Team tips -leaflet said) and didn't notice such a big difference between the tire with weights. Maybe the car won't flip THAT easily with the weights, but still...
I'm going to get the Moab 2.2s today from a friend, let's see how it goes with them. Hope it helps.
Old 06-10-2007, 10:56 AM   #8
So... Bought a set of Moab 2.2s from a friend. Cut the foams to wheel's width and into star pattern. Got rid of the lead balls in wheels and added them to axles.
Man... The car goes MUCH better now! The tires bite the rocks compared to red rocks .
New pics... http://tomik.luola.net/index.php?dir...Crawler&img=13 and forward...
Now painted ... http://tomik.luola.net/index.php?dir...Crawler&img=27 and forward ...
Old 10-16-2007, 11:51 AM   #9
Hmm... Star cut foams?
Hi there,
Did anyone ever post a pic of this? I would like to see what the pattern looks like.
Many thanks!
M
easyrabbit is offline   Reply With Quote
Old 10-16-2007, 01:58 PM   #10
K_B
This forum is like God... it helps those who help themselves... found this doing a search
Star Pattern Template
Sorry, had to bust your nuts a bit... Personally, the star pattern doesn't soften the foam up enough for me. Additionally, I cut a v-notch down the center of the foam to allow the center of the tire to squish in but still provide some sidewall support. The star pattern alone may be enough but for a lightweight rig such as mine, the v-notch down the center did wonders.
K_B is offline   Reply With Quote
