Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > PTI Goliath
Thread: revo links
Old 06-20-2007, 07:24 PM   #1
Default revo links
i recently bought the red aluminum turnbuckles and standard push-rods for my revo and stuck the old ones on grc. and they work great. i used the push-rods for the upper links and the turnbuckles for the lower links and it made the wb 12.25 inches. also i got about 100 degrees of articulation w/o shocks.
just thought i'd try toget some i deas goin if nobody has done this already!! any responses would be appreciated. thanks
goobs is offline   Reply With Quote
Old 06-20-2007, 08:11 PM   #2
I did the same. I used the Revo toes links for lower links and the pushrods for the upper links. You can check it out here: My PTI Goliath Ver 8.0
Skeeno is offline   Reply With Quote
Old 07-05-2007, 03:58 PM   #3
I would like to see more work out of you goobs.
headin out to the LHS anytime soon?
danielk is offline   Reply With Quote
Old 07-05-2007, 04:01 PM   #4
whats the length on those. wonder how they would work on a wk?
admiket is offline   Reply With Quote
Old 07-06-2007, 08:18 AM   #5
the links are 102mm. and 128mm long.
