Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > PTI Goliath
Thread: Goliath BMVII
Old 06-21-2007, 10:45 PM   #1
Default Goliath BMVII
I'm almost finished with my PTI BMVII build. I need to pay my $20 so I can post pics. If you interested the pics are posted here.
http://www.one18th.com/forums/showth...142#post400142
FYI, TC3 differential input shafts drop right into the pti axle housing. I dremmelled a flat spot onto them and slid traxas metal yokes over them. Now, if I can figure out how to get the shafts onto the u-joint without any blood loss.
kawika is offline   Reply With Quote
Old 06-21-2007, 11:15 PM   #2
666
666's Avatar
This interests me a bit, I am planning on getting a PTI soon, and have a BMVII. Keep us updated!
666 is offline   Reply With Quote
Old 06-22-2007, 12:48 AM   #3
What's this "BMV II" ?
Edit... Here's something BMVii .
tomik is offline   Reply With Quote
Old 06-24-2007, 05:50 PM   #4
It's up and running. It sidehills great and climbs very well. I'm slowly adjusting to the limited articulation, but so far I'm very happy with it. The low center of gravity makes up for the loss of articulation. The rest of the build is here:
http://www.one18th.com/forums/showthread.php?p=400762
Old 06-24-2007, 07:05 PM   #5
wow i like that truck .Are you going to change the body on it?
drc323 is offline   Reply With Quote
Old 06-24-2007, 07:19 PM   #6
Great looking truck!
I love the BMVll chassiss, IVe built 3 now and working on my 4th. to get more articulation and pressure at the corners slowly increase the weight in the tires.
Been working with several of them, one at the comp today and it currently has about 4oz of weight at each corner. He is going to up it to 6oz and see how it does
I have mine around 5 oz to start with, waiting on the chassis
rockwerks is offline   Reply With Quote
Old 06-25-2007, 01:18 AM   #7
I still want it to look a little like the GRC. You can't forget your roots .
Old 06-25-2007, 01:21 AM   #8
Thanks. What is the total weight of one of your wheels? I'm a little weary of adding more mass to the wheels. I'd rather put it near the ends of the axles.
Old 06-25-2007, 09:50 AM   #9
total weight wheel/tire/foams/weights is right at 7.5oz each on the axial bead locks and 10oz each on the rc4wd beadlocks
the axial beadlocks need more weight. Im thinking 9oz at each corner would work out well
Old 06-25-2007, 01:35 PM   #10
Does placing weight near the steering knuckles have the same effect?
Old 06-25-2007, 02:42 PM   #11
yes it would help but be impossible to add enough weight to help at that location, and the farther out the weight the better the performance of the BMVll
Old 06-25-2007, 03:27 PM   #12
K_B
What about using thinner wire with less weight in the wheels? My concern would be putting too much stress on the knuckles in the event of a nasty rollover.
K_B is offline   Reply With Quote
Old 06-25-2007, 04:29 PM   #13
thats not much of an issue may guys are running 10oz or more in each tire. on a TLT I forgot this is a plastic geared rig
Old 06-26-2007, 03:01 PM   #14
Curious about the BMV II chassis... How thick are the metal rods?
Old 06-26-2007, 09:47 PM   #15
About 3/16 of an inch.
Old 06-26-2007, 10:49 PM   #16
Thanks .
Old 06-26-2007, 10:59 PM   #17
Originally Posted by tomik View Post
Thanks .
much smaller than 3/16"
Old 06-27-2007, 03:23 AM   #18
Got it out on the rocks today. It worked so much better. Here's a few pics. http://www.one18th.com/forums/showth...716#post401716
Old 06-27-2007, 08:32 PM   #19
wow man that thing looks really nice!
Turblankas13 is offline   Reply With Quote
Old 06-27-2007, 11:22 PM   #20
Thanks.
Rockwerks the diameter is actually 1/8 th of an inch. I just stuck a drillbit in the hole.
