| | #1 |
| Newbie Join Date: Jun 2007 Location: Over There
| OK. I got most of the truck together but I'm having a problem with the suspension. When I push down on the front or back it does not come back up. I checked all the screws and none of them are over tight. I was thinking it might me the springs are too weak. If anyone could help that would be great. Thanks |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Apr 2007 Location: Kapahulu Safeway
| Have you tried adjusting the pre-load on the shock bodies? Compress the springs a little and you should notice a difference. Don't glue those tires to the stock rims!!! Buy something else that uses a hex. |
| | #3 |
| Well, that was easy. Don't know why I didn't think of that:? I already glued the tires, but I drilled out the holes and put bigger pins in the axles. That should hold me over until I get some better rims and tires, then I'll go with the hex. Thanks kawika |
| | #4 |
| I wanna be Dave Join Date: May 2006 Location: Arlington, VA
| dont put too much tension on the springs, with a crawler you dont need it too fully uncompress, or it wont make much of a difference anyway. you could even call it a partial droop setup |
| | #5 | |
| I wanna be Dave Join Date: May 2005 Location: Anchorage, Alaska
It also helps keep all four tires in contact when your suspension is all twisted up and keeps your rig from unsettling when your suspension returns to a more neutral state coming out of an uneven section. | |
| | #6 |
| Thanks guys. As soon as I get my batt. mounted the way I want it I'll be able to test it out. As of now, every time I try to climb something it falls off |
| Thread Tools | |
| Display Modes | |
